More wheel questions...
Alright. I bought two Chrysler Crossfire wheels today at a flea market. I paid $10 each
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. Last edited by B 4 You; 11-19-2012 at 12:30 PM. |
Re: More wheel questions...
The SVX uses 12x1.25 studs, the Crossfire is 12x1.5. The holes are already larger than the studs on the SVX. By drilling them bigger again I think it would have the same effect as trying to drive on wheels on which the holes are oblong from being run with loose lug nuts. The nuts will never stay tight no matter how many times you torque them.
Don't do it. |
Right, but isn't that where the wobble nuts would come in? Hub centric rings should keep it steady as well.
![]() I just kinda like these. Would love to make them work. ![]()
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. Last edited by B 4 You; 11-19-2012 at 12:32 PM. |
I think the nuts would go on too far, past the bevel that is because of the size of the hole.
I've never seen those wobble nuts before. No nut jokes please! ![]() http://www.ebay.com/itm/PCD-WOBBLY-C...&hash=item45ec Friggin' expensive though, $110 plus shipping for a set of 20. Last edited by Blacky; 11-19-2012 at 12:50 PM. Reason: added info |
The studs are the same size!! The stud is 12. The treads are different . I would not tempt the Gods. With the problems this car has with wheel bearings. Getting a good shimmy would not help .
I'd think the hubcentric rings would keep it perfectly balanced. The only think the lug nuts do is keep the wheel on, not balance it. I think it's too much trouble for these wheels. Plus at $10 a wheel, I can make quite a bit off these and make my SVX nicer :[
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
