coolant leak under intake manifold
My car seems to be leaking coolant. I see a small amount of coolant ontop of the block right behind the ps pump. Its not the hose, but I think it is the aluminum tube that runs ontop of the motor.
Any one see a leak from this location before.
No, but it doesn't sound good. Is it bad?
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
I remember when I replaced the coolant temp sensor on mine I gave that heater tube arrangement a once-over and thought: Sure would be a PITA if that thing ever started leaking. Guessing from that memory, I suspect the intake would have to come off to get to the thing.
dcb |
I'm asuming that there is a gasket between the block and the coolant tube. Looks like a pain to get in there and replace it.
Hey Beef,
Question for ya. I didn't realize you replaced your hoses when you installed the PWR radiator. When you installed the silicone hoses, did you use new clamps? What style of clamp are they? Are you using a higher-than-stock radiator pressure cap? The coolant you see around the base of that aluminum pipe (that comes out of the top of the block) may actually be dripping down from the back of the coolant hose. If the hose clamp isn't tight enough or can't apply enough pressure, some coolant may leak when you turn the engine off (coolant is no longer being circulated by the water pump and cooled by the radiator - hot coolant expands and the top & bottom radiator hoses are the only places in the system that will allow any significant expansion). Can you take a pic of where the leak is coming from?
I used T-bolt clamps and the cap that came from PWR. I have not had time to look closely at my car yet. I'll try to get some pics tonight.
