A few more questions...
Yup, more questions from Techy.....
First, How does this look in the cylinders? It's my first time so I'm not 100% sure what I should be looking for. Is the crap that is on the piston supposed to be there? Can/should it be cleaned off w/o tearing the whole thing apart? Second, How does this cylinder look? Ben mentioned to look for scoring, but I'm not sure what exactly that is. I assume it means some kind of scratching. Third, What is the best way to clean off the goop from the old head gasket, etc... I tried a light scraping on a very small section but it looked like it put a few very very tiny scratches into the aluminum so I stopped.
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
Re: A few more questions...
Those cylinders look to be in beautiful condition. You can still see the cross hatching from when it was honed.
I think if you use a bit of heat (heat gun) and a plastic scraper the old gasket material should come off. Maybe some solvent for a final cleaning. |
looks real good, but the bearings will go far sooner than issues with the walls.
2000 Impreza RS-EG33 1995 Impreza L-ej22 1992 SVX LSI- gutted and scrapped |
the cross hatching you see is fairly typical for EG33 engines in the 150k mile "age". What you'll want to do, assuming you can borrow the right instrument (internal bore guage) is check to see how "in round" the cylinders are and to what extent, if any, they've developed a taper (variance in ID as you move down the cylinder). Since you already have the heads off, it's too late to do a leak down check (you might still want to consider doing one once you've got the heads back on). Given the concern that LAN and YT have voiced regarding the rod and main bearings, I would suggest looking into checking/replacing them while you've got the engine out. While I'm not necessarily recommending the "blue printing" approach that LAN takes (mandatory use of a machine shop to do it right and the $$ that go with it), you could at least go the plastigage route to see if anything is seriously "going South".
-Bill
What are the concerns with the bearings?
they can be set up too tight from the factory, which shows up under "extreme" loading. If you check out LAN and YT's threads, you'll see they recommend staying away from the tight end of the specs in the shop manual.
-Bill
