I found a lot of water backseat floor, passenger side???
I just found a large amount of water in the backseat floor, passenger side, I can't see any evidence of a leek.
The car sits outside and it rains continuously here in Vancouver. Can somebody possibly explain a logical reason for a water buildup here? Is there a sunroof drain that runs somewhere nearby that could cause this? or a floor plug that may have become dislodged? The water appears to be concentrated under the passenger seat and to the floor behind, lots of it.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
First, check the trunk. Make sure it is dry.
There are sunroof drain tubes that run in that area. I don't know exactly where. Take a thin piece of long wire and make sure they are not plugged up. Start at the sunroof.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
Thx, I'll try that, and look in the trunk too. haven't checked there yet.
I did wash my car outside the other day, but not sure whether I was spraying water under the door?hmm.
Didn't you drive in rain/snow when you drove it back from MD? If the inside didn't get wet then, maybe you should modify your car washing technique.
I think it must be my car washing technique, or something simular.
No water in the trunk, so I've just opened the sunroof in our underground parking, hopefully it will dry out. Then see if it comes back.
Re: I found a lot of water backseat floor, passenger side???
I would recommend removing the front seat, sopping up the water and get it good and dry. Then lay down towels along the floor (prop up the carpet/pad so it's completely off the floor boards) and check frequently to see if it gets wet in the front first or in the back. The water will always migrate to the back so you need to find out where it's coming from. Then run a hose in different areas until you see where it's leaking. GOOD LUCK TO YOU!
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
Had that problem with the Justy. Problem was the rocker panel area was filling up with water and not draining properly. Unfortunately the next highest drain point was to the interior.
Solution was to dig out the grime from the 3 drains with a screwdriver. Haven't looked to see if the SVX has the same drains.
I am currently going through the same thing, except on the drivers side. After removeing all the interior side trim, seat and carpet, and spraying the whole car with water, the site of the leak was found to be at the door weatherstrip just above the little black triangle at the bottom back lower portion of the driver's side window. The water was squeezing through here and tracking down the body side weather strip into the car and down to the floor board. You may want to check here if your car has never been in an accident, as on casual inspection, no change in the weather strip is apparent. Good luck. Bill Z
No matter how much water you used, or what your washing technique is (assuming the windows and doors are closed ), there's no reason to be getting water where you are.
Keep looking for the leak. Also, let it air dry (no heat) or it might get stinky... |
I need a dry place to let it air out, my work parkade doesn't help much, but since its been raining continuously here, I can't tell if its getting worse.
I will definately check the door drains, If I can figure out where they are. And I did notice a little trickle on the front drivers door area coming from just behind the inside door skin. One thing I can say is that I did remove the passenger side door skin to check for a rattle, and replaced it without much trouble, I'll have to look closer to see if I can find some evidence. I still hope it turns out to be something easy....
Re: Re: I found a lot of water backseat floor, passenger side???
Use blue paper towels, as they will highlight any liquid they come in contact with.
I had this problem on my driverside. Water was coming in from under the door skin and running under the drivers seat. I pulled the panel off and ran water around the door. Turns out it was running down the window split rail, dripping on to the door wirering harness, and running in to the other side of the plastic on that. Very screwed up that every thing had to be lined up perfect for the water to get inside. Then again if you had the door apart and the plastic off you just might want to make sure it's sealed good again.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
Anyways, once all the carpet was out, O hosed down the car and say a small dribble of water running down the inside front of the rubber door frame trim. I assumes it was not sealing properly, so I removed it and tightened the grip by squeezing the C shaped groove closed. Then, added some silicone to the edge, and pushed it all back into place. waited a while, then tried the water again. Crap, still the same problem, so I looked around to see where it could be coming from, checked all the grommets and rubber plugs, they where solid. Now that mention your resolution above, that would make perfect sence. Since I had not had a problem, that I know of, until after I pulled the door skin off, so I'll cross my fingers and check the door to car wiring harness channel. BTW, that sponge under the carpet is never going to dry out.
Maybe you could just drill some holes in the floor and that way the water wouldn't just sit there! Sorry, I had to do that. Hope you can find the leak. That is very frustrating to keep trying things and not get it solved. Did you take the seats out to get the carpet out of the car? Just wondered.
