Tire Width Question...
What width tire would fit on the SVX? I'm planning on getting 17" rims and was kinda curious about going a bit wider with the tire. If I'd bump up to a 235 would my side ratio be 40?
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Buy the widest rim that you can afford, and put the recommended width tire on the rim.
I'm running 245-45/16 tires on 8 inch wide rims with 50mm offset and have had no problems at all with the tires rubbing.
-Bill
Well part of my ? was answered. But if I were to run 235s or 245s what aspect ratio would I be looking to get?
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
You can get a 245/55R16 on there stock but just barely. Anything more would require some spacers. Will have 275/50s on our racer in the near future but that involves some creative sheetmetal work. Not sure on the height aspect but would suspect a 40 would be as close as you could get to the same circum.
I like your avatar......I used to work there......It's more like ....we damaged it again! |
