How much is my 1995 SVX AWD L worth .. AS IS!
Since my "free parts source" dried up.. for my necessary (new) head gasket repair on recently rebuilt engine.. YIKES! .. I'm seriously considering selling SVX as is.. ???
What is it worth? You can see the mods on my signature below. just needs a head gasket.. . Please give your BEST GUESS? (West Coast of course..) Thanks, Jim P.S. 236K total miles .. New "rebuilt" low miles engine.. all gaskets (incl head).. head bolts.. water pump.. oil seperator.. timing belt (ebay) kit.. thermostat.. coolant temp sensor... Ran great til head gasket leak (heats sl on long or hot trips).. I have head gaskets and many extra parts.. like HD headlamps and wire harnesses, AT pan gasket, bulbs, miscellaneous studs, bulbs
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 11-12-2013 at 11:04 AM. |
Re: How much is my 1995 SVX AWD L worth .. AS IS!
Maybe nothing...
Keith Sorry. =( |
Post pictures of interior and exterior of car it might just become a parts car, taking into consideration that a head gasket job runs between $1,500-$2,000 that might leave the car at no value as a whole. If I was still living in California I would pick it up!
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
You're looking at $1000.00-$1500.00 at best.
1992 Dark Teal LS-L 237k #103994 (Sold) GC8 Nardi Steering Wheel/ Crossed Drilled Rotors/ 18" Exel Evo Wheels/15min Mod/ 6k HIDs/ECU Crush Mod/ Power Mode Mod 1997 Brilliant Red LSI 151k #100109 PWR AU Radiator, Stebro Catback, Hella Supertones, SS Brake Lines, Cross Drilled Rotors, QC, Power Mode Mod, SSR GT3 Wheels 18x8 et35 1997 Ebony Mica LSi 177k #100321 |
