RWD biased AWD systems..
So i just saw a commercial on television for a new Infiniti which is just RWD when most other AWD cars are powering the front wheels.. are there any other awd sistems which do that?
lambrogini? nissan skyline? probably the same thing as an infiniti g35 anyway.. but the i-car doesn't have turbos porsche? any cheap cars with the rwd/awd setup? -adam |
UK SVX?
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
No no no.... The SVX's have the same power distrabution all over the world... It's not 90f/10r like most of us have heard... It's 60f/40r..... And yes there are some RWD biast AWD systems out there... Porsche, the Audi Quattro system, Lambrogini.... All of them favor the rear wheels over the fronts...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
audi has the same set up FWD plat form along with the subaru and such
skylines are RWD plate forms along with some other cars out there,
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
I know this probably isn't what you're looking for cause it's a truck, but the Chevy Silverado SS is "RAWD"
http://www.cars101.com/subaru_svx.html The non-USDM SVXes have a different style of center diff, and the power distribution is more rear-biased. Here is some info on the non-USDM SVX center diff: http://www.subaru-global.com/about/parts/06.html
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 12-16-2003 at 12:39 AM. |
I have found a few more pieces of evidence and information, but I cannot find any proof, one way or the other.
http://www.imprezawrx.org/editorials/981027/awd.html http://www.ravensblade-impreza.com/t...s/pdf/pdf.html
torque split.
When we quote torque splits of 90/10 front /rear. this is just the way we define the two different types of AWD units.
We could also say it is 100/0 when the FWD fuse is fitted. This clutch type AWD can deliver torque to the wheels 90/10, 80/20, 70/30, 60/40 and locked up 50/50. It depends on the amount of transfer clutch pressure that is applied. No pressure 100/0, full pressure 50/50. The trade off is the higher the clutch pressure and the torque split, the more the center diff can not accommodate a difference in wheel rotation. Binding will occur, so it will use a lower pressure under normal driving to prevent binding. In a tight corner it will be biased to front drive. The epicyclic center diff uses a different number of teeth on the front sun and planet gears than the rear sun and planet gears. This difference is in the ratio of 36 front 64 rear. This can also vary to 40/60, 50/50. The main effect in the way the car will handle is in the amount of torque that can be applied in cornering. Because all the rear drive has to be delivered through the same clutch, that has to allow wheel speed difference. The US clutch type can't use a lot of rear drive in corners. The Euro diff type uses gears to transmit drive to the rear wheels, the clutch is only there to prevent wheelspin. So that the 36/64 Torque split can be applied in corners and still accommodate the difference in wheel rotation that happens. Harvey.
Several Subarus currently use a rear biased AWD system... actually a couple of different systems. The Outback VDC, Legacy GT automatic, Forester XT automatic, and Baja Turbo automatic all use a system called VTD (Variable Torque Distribution) that combines a hydraulic transfer clutch with a planetary gear set to provide a 45/55 front/rear split. The other rear biased system is on the WRX STi, which provides a 35/65 front/rear split. Both of these can of course adjust to a 50/50 split.
The other Subaru systems are the familiar 4EAT with 90/10 up to 50/50 front/rear split, and the 5spd tranny with the viscous coupling providing a standard 50/50 split, variable up to 0/100 or 100/0.
Shane 92 SVX - Sold 98 BMW M3 Sedan 89 Honda CRX Si w/B16 swap 91 Honda CRX Si |
(I can strip a gearbox, no problem, but then I get stuck!!)
Re: RWD biased AWD systems..
BMW's AWD system is 20/80, well cya
Cheers. Harvey.
