Cruise Control
When i try to get the cruise control to work. Hold it down and just does not take.
Is it Possiable that i just might need to reset something some where? thanks for anyhelp. |
This is a common problem. You can replace the switch, if you can find one. I have seen posts that suggest going behind the glove box and finding the main control box and cleaning contacts. I replaced my switch, or rather, Subaru replaced mine under warranty. It lasted for about 85,000 miles and started displaying the same problem you have. I have learned to live with it. If you GENTLY slide the switch eventually it will take hold. Mine takes about three tries sometimes. Yeah, it's a pain in the butt, but it's a lot cheaper and less trouble than replacing the switch. I have to use the same gentle touch to get it to turn off. By the way, mine heals itself when the temperature gets below 40 degrees.
'92 LSL TEAL 277,000 miles Trans (on # 3) Engine (on # 2) "NEW" VISORS '03 Forester XS 214,000 miles '05 Outback 3.0R |
Do you mean that the switch will light up but using the set lever doesn't work?
If that's the case, then the vacuum hose has probably detached. Mine used to do that all the time until we put a very small hose clamp on it. ~~Michelle
~~Michelle ----------------------------------------------- '92 LS-L - copper - 190K miles '94 LS-L - pearlie - 92K miles *still have '92 parts* |
Clydesvx and Michelle, Thanks for your reponces, I will look at both those options.
Michelle do you know were the vaccuum hose is located? thanks. |
I'd be interested to know more about this too as my Cruise Control decided to stop working last night also. The switch on the dash lights when it's depressed but I can't engage the C/C from the paddle whichever way I push/pull it.
It's worked fine every time I've used it until last night, it gave no sign of failing in the lead up to this.
The Monzta '96 Subaru SVX (111K) - UK spec '85 Opel Monza GSE (71K) '86 Opel Monza GSE (95K) '93 Toyota Estima Lucida (37K) - JDM import My psychiatrist says I'm suffering from paranoia........but he's always hated me!!! |
It's right at the top of the firewall on the driver's side.
~~Michelle (Sorry I didn't include that before)
My hose always fell off too. Good call Michelle!
I was going to say that too!
My hose had fallen off too. Will test the CC out tomorrow to make sure it's cured.
Whilst I had my head under the bonnet I noticed a short rubber hose coming out from the top of the tranny that bent round at 180 degree angle (a little like a question mark '?') with the other end connected to nothing. Is this just a breather or has it come adrift from something?
Thanks again guys. I will check this weekend to see if it is just the hose.
I Would like to thank everyone, My Cruise control is now working, IT was just the Vaccum tube. I tie it down. . Thanks :-)
This place can save you a bundle of money if you let it.
