Mobil 1 High Mileage 5W30 Used Oil Analysis
I did a UOA on the M1 5W30 High Mileage oil I had in the engine for just over 6000 miles. I also had the Bosch Premium oversized oil filter and the AC Delco air filter on the car. However, I changed the air filter just before putting this oil in so there may have been some contaminant in the engine from when it had the K&N air filter in it. A couple of things that jumped out at me was the high TBN which means the oil had plenty of life left in it. Hell, some oils START with that level. There was also no measurable water in the oil. Yeah, my headgasket really needs to be replaced...NOT! The oil sheared down from 11.7 to 10.5 which doesn't seem too bad and the wear metals were nice and low. Has anyone else ever posted a UOA from an SVX?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 02-26-2012 at 08:56 AM. |
Re: Mobil 1 High Mileage 5W30 Used Oil Analysis
Hi everyone, I was recently at the Mobil 1 website and looked at the recommended oil for most protection in my 2011 Legacy 3.6L. Mobil recommended the 5w30 extended life Mobil 1. I think this would be a good choice for the SVX although in the 10w30 oil. I do not plan on running the oil 15,000 miles or 0ne year in the Legacy but I might in the SVX as I drive less than one thousand miles a year. Take care, BOBB
I'm registered at Mobil 1 also.
Based upon huskymaniac's suggestion and analysis, I am using Mobil 1 0-40 with the Lubeguard BioTech Protectant. My rebuilt longblock by AWD has less than 9,000 miles on it so a high-mileage oil is not needed. I drive less the polo less than 600 miles a year now and sometimes it is 3 months between starts. I wanted protection against dry starts and a weight that would flow easily into tight clearances in cold weather. Read this post. http://www.subaru-svx.net/forum/show...96&postcount=5 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-26-2012 at 06:45 PM. |
Looks like I'm switching to 5w-30 M1 MH my next oil change.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
"Tonyistheoilguy" Thanks for posting that Tony! I may transition to the 0W-40, been using the 10W-30 M1 HM
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
How many miles are you going on the oil? Right now I am buying the 5 quart container of M1 5W30 HM and two quarts of the 0W40. The addition of the 0W40 brings the HTHS up very close to the threshold suggested by German manufacturers who are concerned about shear in high stress engines, still gives me some seal conditioners and flows well in winter temperatures. The 0W40 also helps increase the base number to enable longer OCIs but the straight 5W30 M1 HM seems to be good enough in that respect for my 6000 mile interval. I have to admit that this analysis has me tempted to push it higher though. I just don't know how long I want to keep that filter on there.
