Stock wheel backspace
Hello,
Could some kind person with a stock wheel off his/her car put a straightedge across the inside edge of the rim and measure the distance to the mounting surface of the wheel ? Are the stock wheels 16" x 7" or 7.5" ??? Thanks for the help its much appreciated Hotshoe |
The wheels are 7.5" and 55mm offset. I haven't measured them myself but this is what everyone else says they are.
Thanks but....
David,
I too have seen that number but somehow backspace and offset are not the same number. offset is the difference, positive or negative of the mounting face from the midpoint of the rim width: hence 7.5 inches div by two plus (or minus) 55mm... I am trying to get the actual number on an actual wheel representing the bolt mounting face of the wheel and its distance from the inner edge of the wheel. Pretty sure that it ISN'T 55mm Thanks for the help tho' Hotshoe |
Earthworm is right. I measured mine with some instruments that a friend had who was plant engineer for Volvo production. The full detail is on the Yahoo club. If you do a search for posts under my name you should find both the winter rim & summer rim specs. It was about 2 years ago.
Like a dummy I can't put my finger on them now. |
hmmm...in that case does 163mm/6.4" sound right?
Seems like it was 3 years ago.
http://www.subaru-svx.net/archive/ar...p?message=9130 http://www.subaru-svx.net/archive/ar...p?message=9101 Last edited by SVX_MY_BABY; 01-22-2003 at 08:00 PM. |
the inner-outer rim width is 8" and the offset is 55mm from the center so 55mm + 4"(half the rim) = 156.6mm sound right?
oops...didn't see the second link with the alloy rims.
backspace
Yeah David, I think that we're there...
Which steel wheel was 8 inches wide??? I think the 6.4" must be pretty close to the answer. Thanks for the tekkie stuff. Itw as -22 last night and Suby2 started right up, you've been having the same cold spell too, haven't you??? Take care, Richard aka Hotshoe |
Canadians eh?????
Hey, this is fun,,
All the participants in this thread are, so far, the Canadians.... Is that just luck or what??? Hotshoe |
It was colder than -22 here last night...and that doesn't include the windchill.
re: sheesh canadians :D
just putting a kink in the chain, a fly in the ointment. i as you can see am not canadian.
muohahahaha.........but you know what's funny? my svx is from canada! even has a canadian flag i can't remove from the trunk lid! DOH! |
Re: backspace
BTW -18 C here last night, but only -8 in the day. Positively tropic! |
