Just a quick note so no one thinks I'm just BSing, I've got preliminary numbers coming in at around $1500, not including an accurate injector price or the custom pipe work. I won't go into too much detail here as it would get kind of complicated to explain my setup, but briefly:
Single Mitsubishi 16G (regular one, for those who know them): $525 A pair of 450cc injectors (don't ask just yet, I'll explain when I'm closer to done): estimated $200 Greddy e-Manage w/software and inputs: about $500, Other turbo parts: about $200 Other fuel system parts: about $80 Michael, if you're interested I'll PM you with a more accurate description of my current intent.
My two loves: SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2 |
Tapping the two throttle bodies with a pair of injectors is one way to do it. Kinda like a permanent wet nitrous kit. Your costs are fine for a DIY kit, but for someone who's going to bring a kit to market, you also need to include exhaust system and intake system design and fabrication costs which will not be cheap.
Let's all get one thing right. Longassname is making a roots style blower system, if you want a turbo?? make your own system, spend 7 grand on a system you will be trying to tune for a couple years. He is making a clean system that will be dependable and probobly gaurenteed to work if installed properly. a single turbo for our cars is custom and not gaurenteed to work to it's full potential. Let him develope his system and stop badgering him about what you think is better. Also, if you are torn between whether or not a turbo or blower is better, use both. I've seen it done on an mr2 so do that to make sure you have the best ever. Im really anoyed at people telling him to do something else, do it yourself if you are so confident.
what you doing is actually contradicting his own work. You are mearly taking a shot in the dark as where he has done the research and has come up with the most cost effective, and reliable way to make power. If you can do better prove, just somewhere else and then come back when you have results. Just make sure you know that you are not dealing with an eclipse, this is not a normal engine and won't be as easy as you think, ask anyone who is still trying to figure out what the hell they are going to do with their turbo svx?? Almost all of them have their own problems
There's also engine timing under boost to consider. How do you plan to deal with that? So you're going to use an external wastegate? Do you plan to route the waste gate exit to the rear of the car and put a muffler on it? If not, then you'll get a ticket pretty quick.
I split this discussion to it's own thread - please reply here about the turbo kit to avoid confusion in the other thread.
hey guys come on now. let's not get into a fight over here. i'd say let both create their kits and then compare. the results will be proof. hats off to both of you for trying to fabricate something that isn't available for our prized possession.
Exactly! I'm with Noir
I appreciate the support Noir, Chiketkd. The other thought that's been in my mind, particularly since the backlash from certain members began, is that competition creates innovation, so if this is a competition, the community can only benefit from it. All I really set out to do is prove him wrong on the point that a turbo kit capable of the same gains couldn't be setup for siginificantly cheaper than his setup, so that's my primary goal. If it results in a decently effective turbo kit for our cars, all the better, if not then his supercharger will still be there as an option for those who want it.
As far as the timing, the e-Manage is capable of handling that as well; it may be fun figuring out how to wire it in, but we'll see. As far as fabrication costs, I'm not looking at that many custom parts. There will be a modification to the existing manifold sending both sides to a collector at the turbine, a pipe back from the turbine to around the points where the headers attach to the exhaust now, and two pipes for the intake. None of them are particularly complicated. From what I've seen of other people getting pipe work done it shouldn't be that expensive, and I think it could pretty easily fit in the remaining $500 of my estimate, though I suppose another $100 or $200 beyond that is possible. Its a little interesting that someone mentioned an Eclipse, as that's where many of the parts are coming from (the turbo, blow-off, injectors). I need to check with my "consultant" (DSM-owning friend whose given me most of my setup ideas) to be certain, but the wastegate should be dumping into the normal exhaust system, I see no reason why that would cause a problem. And tomssvx, how is this not a normal engine? I see nothing particularly special about it, no issues that would be present with this that won't be in Michael's setup. Now, unfortunately as I mentioned, just so everyone understands I'm only a college kid on a living on a Wal-Mart paycheck. As long as I'm living at home (the forseeable future right now) most of that paycheck can go towards this, but it will probably take me a while to have anything to show. On top of that, none of this is coming off the drawing board until my transmission is finished and reinstalled, though that should be soon, just awaiting a few parts.
If you dump the wastegate stream back into the exhaust pipe, the factory exhaust is going to choke the motor at high rpm/throttle position. longassname will have the same problem. It will work, but you'll be nowhere near the full potential of the turbo.
they are different in a couple ways, the fact that our compresion ratio is so high means minimal boost is still pushing the envelope and also the fact that there are close to no aftermarket parts for our motors so upgrades will be rough and heavy on the wallet unlike an eclipse as where you could go to any half assed parts shop and build a car in the parking lot. Its mearly availability and incompatability. The svx is the only car with a flat 3.3 non-interference motor, as opposed to a car like an eclipse where as the same motor was used in several different models, even the turbo was used in the galant for pete's sake. All i am trying to say is the turbo sounds like a great idea but it is not ideal for the svx due to powerband and engine tuning control. The svx powerband takes a dump at around 5400 rpms and the turbo will probobly spool at around 2500+ so that gives you what, about 3000 rpms of good power as compared to the blower will give you good power throughout. Believe me, i am a college kid too, im 19 and done a lot of work on cars for a kid my age, the svx is suited better for a blower than a turbo. But hey i am not one to stop you, if you can make a good turbo kit and produce it for the public thats incredible and i give you my respect, but right now you are still in the drawing stages and won't know a price until you get a good working production model. Also if you do decide to go through with the turbo, you might want to consider a t3/t4 hybrid, it's quite a bit bigger and with our engines it would spoon up fast, also give way for an engine rebuild for more power, just a thought. Speaking of that get in touch with some turbo companies and spill your guts to them and tell them you would have an audience awaiting final production, they could help you fund your project.
a 500cfm(small tdo4-16g) would be a RESTRICTION to a 3.3 litre engine. Reccamended placement is on nothing larger then 2.4 litres. Its a very populer upgrade for 2.0 litre 4g63 dsm's and also in PAIRS to replace the stock duel 13g'd 3k/S VR4's
phil
this doesnt make any sense..
town has an External wastegate, mines a HKS racing version. It exits the excess flow directly into my single 3" downpipe. Its basically the only proper way to do it, What the heck are you talking about ????
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
