bye bye tranny
ok... i'll go over what has happened in the last 2 weeks, and you guys tell me what i should do....
2 weeks ago i felt the trannty slipping.... going fine in 3rd then rpms shoot up...... brought it to a tranny shop, they drained the pan and replaced all the fluid (no flush) for a week, the car drove fine. over the weekend, i took a day trip, and on the way there, tranny wouldnt get out of 2nd gear for a few minutes, but then it would work fine, with 2nd gear banging slightly into third....... on the way back, the car wouldn't go past third gear.... so, this morning, i bring it back to the shop, and on the way there, it won't get out of 2nd gear!!! tranny shop wants to do a remove and rebuild, using subaru parts for a cost of around $2500........ i told them to give me a few days to ponder, then the guy calls me an hour later and says he thinks it may be an electrical problem....... the tranny has about 20 - 25,000 miles on it, and i wasn't anticipating replacing it so soon...... HELP!!!!!!!! btw, i would love to do a 5 speed swap, but it would have to be done at a shop, or at the very least, someone other than me... anyone have any ideas of how i should deal with this? would it be the same price for a swap, if i do need a new trann? (that was my plan all along, to put a 5 speed in after the tranny fails) sorry for the length of this, im not a "car guy" and i need some help... thanks!!!!! kris |
I'm not 100% sure of this but i think the 5 spd swap might actually be cheaper than auto. Its hard to find a shop that will be willing to do it. Many people here have done the swap so im sure they will be able to tell you what you need to know. Do you have another car or is the SVX your daily driver?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Oh i see that your in Long Island. I was just in Hicksville tonight at my cousins house.
DAILY DRIVER
it is my daily driver, but i could do without it for as long as it takes to do a swap.... does anyone know of any shops in ny that'll do a swap?
also.... could this really just be an electrical problem at this point? |
You could try Lee Miles transmission specialists. There are alot of transmission shops in yonkers, bronx,queens, any of those areas.
UPDATE
okay, the tranny shop says tranny is fine.....
says its a computer problem with the TCM module? did a search and didnt turn up a tcm at all, maybe its got a different name, its the computer that controls the tranny... HELP!!!!! |
TCU?
yeah tcu
yeah i guess it is the tcu.... now car is stuck in 2nd!!!!!
trying to unhook tcu now to see if she'll stay in 3rd.... |
unhooked tcu
i unhooked the 3 wires (clips?) from the tcu and drove car again...
car is still stuck in 2nd.... what the heck is goin on?!? |
Your car is in limp home mode. plug everything back in and pull the tranny codes. There is a failed electrical part somewhere.
Mike |
thanks
thanks for the help, on my way to auto zone now, will post results
maybe not....
auto zone tells me that the car has to be a 96 or later to hook it up.... i guess i'll have to bring it to the dealer ... didn't want to do that, but if anyone has any other ideas please let me know
Tranny codes can be pulled if the problem is electronic (power light flashing 16 time on startup).
See the method on http://svx-iw.com/ (click codes)
help help help
put the car in test mode, power light blinks steady, i guess this means there's no problem with the car, besides the fact that its stuck in SECOND!!!!
tranny shop says tranny is fine but computer is bad car says electronics are fine.... help me!!!!!! |
Re: help help help
When the high clutch fails, it will start to slip in 4th, as it has the highest load in this gear. It only has to slip in this gear for a short time, before it will then slip in third. The TCU can't cause the transmission to just slip, instead of engaging. It will either engage the gear or not, it wont make it slip and rev instead. If the TCU has electrical problems, it will defualt to only engaging third gear. From your description, it now will only start in first, shift into second, but won't go into third or fourth. The high clutch has to hold to get third and top. Harvey.
