Ignition Key
My wife broke the key off in the ignition.. I was able to remove the assembly from the car.. What is the trick to getting the tumblers apart so i can remove the broken part of the key
A really big hammer . . . Oh, did you want to be able to reuse it?
Depending on how far in it broke off, you might be able to grab the end of the key with a narrow pair of needle nose pliers or diagonal cutting pliers (aka dikes). Or, maybe use a straighened paper clip? Good luck,
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! Ticking from front of engine, passenger side - Stuck lifter? |
1.Try tapping it while holding it upside down to drop out the key
2. Try a strong magnet while tapping 3. Use a coping saw blade ( blade only) It's small enough to slip in enough to grab the key, make sure the teeth are facing out when inserting. As you pull it out, the teeth will grab the key. Keep trying, patience. 4. Bring it to a locksmith 5. buy a new ignition switch 6. Good luck! |
How about a medium sized finishing nail with a drop of crazy glue on the end of the head? Hold it against the end of the key for a few seconds and pull straight out.
All of the above are good
I had to do the same thing on an Isuzu Trooper. Tweezers magnets and shaking it finally worked. Don't get impatient.
