climate control issue
The other day I turned on DEFROST at the medium setting and within a few minutes I heard a "beep" like I had pushed a button and air started blowing full speed out of my vents. All of the climate buttons were lighted and my temp gauge showed no numbers. I was unable to select any option so I let it be thinking it may fix itself when I turn off the vehicle. But here I sit with the same complex and I don't know what to do. I've checked all the fuses that I thought might have anything to do with the A/C but they're all fine.
Any help? Here's some pictures of what I see everytime I turn the car on:
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
Re: climate control issue
I dont believe a fuse would be it.... it really seems as if you have a short somewhere. The climate control computer may be to blame.... have you tried see if it will self test for any codes?
need to check.
When you get a whole lot of things going on with a unit, it is likely that there is a grounding problem.
hi since the unit lights up try disconnecting the battery and see if it resets
charlie |
still need to see if there are any codes...work and school are keeping me from it
