how to remove body part
Can anyone tell me if the small body part below the rear window can be removed? It is the one that has the SVX logo on one side or the other on some model years. One of mine is faded badly and the clear coat is flaking off. I would like to remove it for a proper paint job without doing the rest of the car. How do you remove it?
Ken
Ken '94 Bordeaux 1984 Ferrari 400i (4.8 liter V-12) '69 Lotus Elan +2 w/Cosworth BDR '04 Audi allroad 2.7 TT Black |
Re: how to remove body part
Each rear quarter garnish is held on mainly with 8 plastic clips. There is also a clip on the end of the garnish that is covered by a body-colored cap (you can see them when you raise the trunk lid. These is removed as well, along with the power antenna on the driver's side
When prying off the garnish, you will probably break many of those clips that hold it on. They get brittle with age and it is almost impossible to avoid breaking them. be on the safe side and order 16 new clips. The P/N is 96002PA010 and they are about $1.80 each. .
You'll need to be careful with the black edge trim as well. It can be brittle or you can tear it.
In regard to the black edge trim...are you referring to the black weatherstripping? Is it possible to order just that part? Like said, the rubber around those pieces is faded and brittle, if not available from subaru is there an aftermarket alternative? Buying strips of rubber?
I mean the thin edge trim along the bottom & sides of the garnish. I think it's still available as new.
yeah you're talking about the weatherstripping, they offer that rubber piece by itself?
