What is this device under the intake?
I am removing all the emissions control devices from my H6 that is going in my 91 wagon and found this guy under the intake. I don't know what it is as it looks like an IAC by the way its plumbed but the IAC is on the throttle body. I am just wondering its function so I know if I can remove it. I don't see any wiring for it on my engine control diagrams. Also I don't want to hear any "why are you removing stuff its there for a reason and leave it" I hate emissions equipment and seeing as I am doing this as a swap with a huge harness merge I am not going to also wire all the emissions stuff back in so its gone.
Brad
1988 Firebird Trans AM, 1987 BMW 325is, 1978 Dodge RamCharger, 1989 Chrysler Conquest,(2) 1988 Merkur XR4TI 1973 Super beetle Baja Bug 2006 Chrysler 300C SRT8 1996 Buell S1 Lightning 1998 Subaru Forester 1993 Chevy K2500 |
Re: What is this device under the intake?
Those pipes make me think it's something part of the PCV system, which is something I would keep (even though it's emissions related).
Looks like aux. air control valve.
Subaru says it's the "Auxiliary Air Valve", for what that's worth.
Ok auxiliary air valve is going to be gone. as for the PCV I am going to keep that stuff as its keeps the seals from blowing out just a little bit longer. LOL I am actually looking at running an electric air pump as a vacuum pump to the breathers so I don't have to pull the oily air into my intake. that or plumb in a vacuum port in the exhaust.
Thanks so much for the help guys, Brad
Somebody, correct me if I'm wrong... That piece might be influential to your cold idle.
From the FSM: Aux. air valve supplies by-pass air only when engine is cool. Also from the FSM: More than half the air for idling is supplied by the bypass valve.That's under the TB.
No, you are not wrong. I think mine got gunked up when my PCV was stuck and it does cause a bouncy idle when cold.
