? For those with aftermarket soundsystems
I just installed a new head unit and wired my car for a sub and amp. However, I'm not gettibg any power to my amp. All of my connections are solid and the fuses are all good, so the only thing I can think of is that my ground isn't good. Where is the best place to connect a ground wire?
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
Re: ? For those with aftermarket soundsystems
Other wise, find a factory grounding spot or sand off all paint on a spot in the trunk and tap into the trunk-BE SURE TO BE AWARE OF ANY POSSIBLE WIRES AND USE A SHORT SCREW!!! Edit: And just to note, I've grounded back to the battery in 5 separate cars and have a friend that competes in comps who also always grounds back to the battery. Capacitors and extra batteries are actually not a good idea as they put extra load on the alternator. Extra batteries only help when listening to stereo with the motor off when its parked. I have never seen capacitors help a stereo sytem in my life. Last edited by 1986nate; 03-07-2009 at 02:08 AM. |
I unbolted my trunk latch and fed the wire into an eye connector, then reattached the bolt back to the trunk latch. Mine has worked fine for years.
+1 on not using a capacitor/2nd battery. If anything you should be upgrading the alternator wiring.
Thats another good idea I forgot to mention-any existing bolt that already bolts to the car
The less drilling the better.
Where did you have your ground connected?
Can you confirm all your connections with a volt/ohm meter? Are you getting a voltage on the signal wire going to the amp from the head unit?
I checked it this morning with a basic test light, and I'm not getting any juice from the primary power lead at the amp, so I'm assuming it has to be the ground. I found a place under the flap that covers the gap between the back seat and the trunk floor, but apparently its not a solid ground. I have to work today, but I should have a chance after work to do some searching and find a better place to mount it.
I grounded mine on the back seat bolt.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Mine is grounded to the trunk latch mounting bolt, under the plastic trim piece that runs along the rear of the trunk floor.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
Checklist: - check for ~12v on cable going to the amp - check ground cable for continuity to a separate ground - check signal cable for 12v with head unit on If these are all good perhaps there's a problem with the amp or a fuse is blown on the amp.
I figured it out. Turns out the screw I originally used screwed into a plastic clip, which obviously ensured that I didn't get a solid ground. I made a new hole in a metal panel and now my trunk goes boom (it was dark when I did the original wiring job so I missed the plastic part the first time around)
