need specification on the eg33
Hi, somebody can tell me if the ej207 or ej257 oem rod are stronger than the eg33 oem rod?
what is the size of the oem oil pump of the eg33? 11mm ou 12mm? Are you using sti oil pump(they have the 11 and 12mm too) thanks! |
Re: need specification on the eg33
do you know the length of the eg33 rod? Im not sure if oem vs oem, the ej257 have stronger rod vs eg33 |
the eg33 is all EJ22 internals
EJ25 is a stroker version of the EJ22 so pistons/rods are the main difference
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car 86 Lifted GL wagon well over 600k miles on the chassis 98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires |
I just confirm what Im saying, the rod of the ej207 and ej257 are the same length of the eg33 rod(130,5mm) and journal look like the same
But If i want to run the ej25 piston yeah I have to sleeve it but this is not what I want. the only thing im not sure is on a n/a setup, the sti rod is that much stronger than the eg33 oem? |
somebody know if the oem sti rod is that much stronger than the eg33 oem rod?
