Interchangeable Parts
I was wondering if there were any interchangeable drive line parts that will work from other subaru models that will work on the svx. I know the 5spd mt will work are there any drive shafts and or differentials that will easily switch out???
Every post 1990 diff from something other than a Loyale should fit the SVX.
there is a list on here just do a search...
I'm pretty sure that my 97 Leg L pads were the same as the svx's... think i added it to the list too. Most models in the "EJ" line have at least one thing that can be swapped. 4EAT's, brake boosters can be swapped with a bit of help, air filters, check the list.
Thanks I found the other forum.
