PLEASE help, starter bad on Xmas away from home???
I drove down to my mom's for Christmas eve and planned on leaving that night to go home...
Not going to happen :P I turned the key, and got "clickclickclickclickclick" so I figured my battery is dead. I put the battery charger on it and it's already at 100%, put the charger on "Start" mode and "clickclickclickclick" again. I popped the hood and hit the remote starter that's been installed since I bought the car...no idea what type it is or anything. I hear the "clickclick" sound, seems to be coming from the starter area. Is my starter bad? or that "starter interrupt relay" i found in other posts? I've had no issues starting the car up until this moment, so it seems very strange. How do I use the screwdriver trick to get it going so I can at least get home today? |
Re: PLEASE help, starter bad on Xmas away from home???
Try cleaning and retighteing the terminals.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Cleaned and tightened, no change
Kept trying to start it over and over...played with the shift selector, sprayed wd-40 into the ignition (just in case, I don't think that could be the issue since the remote starter also didnt work)
I FINALLY got it to turn over, just by luck the solenoid kicked in or something? No idea, but it's staying running til I get home. I saw the power light blinked at me when it started. That would indicate a tranny code correct? What could it be? No blinky lights before this so it's related...will update when I get home. Input is still very much appreciated...don't think it'll start again so I still need to figure out the problem. |
I wouldn't rule out the battery. I would clean the posts and make sure the battery is charged. The clicking is usually a low battery. Did you try jumping it? That would help figure it out. Good luck and let us know what you find out.
Try making a small wire 10-12 gage) with a spade conector on one end with a 20 amp fuse in the lin, long enough to reach from the starter to the battery.. Push the spade connector on the starter and touch the other end, striped enough to make contest to the + (positive battery cable). Just touch the striped wire and see if the starter turnes over.
If it does, with the ignition switch turned to "run" doing that will start the car. if this works, tape the stripped end so it won't short out while you are driving and go home. If you have to kill the engine, you can follow the directions and start it any time! You seriously have a shot at this working! Merry Christmas, Keith |
