pcv valve problems
Having a problem with the pcv valve. In short my SVX is idling rough and I thought I would start with the valve. Easier said than done. I located the valve, but can't get the thing loose. I am able to get my 19mm crow's foot on the thing, but it is frozen tight. I have tried liquid wrench to try to free up the threads, but as the pcv valve screws upward, I don't think any of the spray is actually reaching the needed threads. (By the way, I am turning the wrench the right way, which is opposite of normal because of the orientation of the valve) Any suggestions or tips would be appreciated. If worse comes to worse I guess I can take the valve I bought to an independent shop to have them install it, but I can't imagine they would have any better luck than I have, and I don't want to end up with a frozen valve with stripped threads.
remove the throttle body, but not the intake manifold.
you can then get on it from the bottom with a deep socket. I just did mine last weekend and it was on there good. I think there is some type of thread lock on it.
Ohhh!! Looky, Looky... That's because you need the "Ultimate SVX Wrench!!"
http://www.subaru-svx.net/photos/fil...ttell/7066.jpg |
John,
Very nice wrench for a stuck SVX PCV I haven't needed one yet. What kind of a torch did you use? John
I had a welder brother-in-law modify the wrench.
Dunno how skinny you are
But I was able to squeeze my hand in from underneath and used a normal 19mm socket to get it off (yes, I'm pretty skinny). I ended up cutting my arm in the process, but it saved me the frustration of having to loosen it from the top. I also used this method to put the hose back on because I could not get it on all the way from the top. It's worth a shot, just have the band-aids ready.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
I don't know if it is too late or if it will help, but there is a How-To in the locker on this process.
If someone would like to borrow the "Ultimate SVX Wrench" let me know!
John
What is the angle of the wrench? Is this just right, or should it be a little more or a little less angle? I am thinking of making (excuse the pattent infringement) one for our NW area. Didn't know if it could be improved or not.
No this wrench can't be duplicated!! I don't remember, I think is was close to 40 degrees. I painted it black!!
That wrench WAS a duplication! I have the original wrench!
You know I think I you have the hooked-up version...Troy, Did you dip your handle in plastic dip to prevent hand slippage?? I was thinking about buffing mine to make it look like a genuine craftsman tool!
I put a racing stripe on mine so it would go faster!
have you tried PB Blaster? its like Liquid Wrench on steroids. if THAT don't work, then you're in for some disassembly.
Mike |
