Old 09-13-2001, 08:21 AM
EveryShadeofBlue EveryShadeofBlue is offline
British Car Junky
Send a message via AIM to EveryShadeofBlue Send a message via Yahoo to EveryShadeofBlue
Dashboard Lit up like a Christmas Tree
I pulled into my parking spot at work today and suddenly many of the dashboard lights go on. These include: Steering, battery, stop lamps, brake, and ABS. The car was running fine and didn't seem to have any problems. I turned it off and started it back up again and those lights stayed on.
Any ideas? Should I "reboot" my car by unplugging the battery?
Jeff
Jeff - Tampa, FL -
Old 09-13-2001, 08:54 AM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
YIKES!!!
Yes, I would disconnect, and see what that does.
Keep us posted!
Kev
kevin.m.sheets@verizon.net
Old 09-13-2001, 08:55 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Dashboard Lit up like a Christmas Tree
Jeff
Jeff, those symptoms are usually indicative of a loose or thrown alternator belt, or an indication that your alternator is on the verge of going out. I'd go to my local Autozone (or similar) who will check the charging system for free, to see if it has to do with the charging system. ( DISCLAIMER: This is just a suggestion based on my experience. I am not a licensed technician, nor do I want to misrepresent myself as being one. ) You can try "re-booting" -- it's cheap and, if it works, a blessing.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-13-2001, 09:20 AM
British Car Junky
Thanks for the suggestions. I just unplugged it (after running an errand with the same lights on). I'll let you know the results!
Thanks,
jeff
Jeff - Tampa, FL -
Old 09-13-2001, 10:26 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Jeff, I had that problem as well. With me, it's the case of grounding. The pin 1 of the tranny harness was loose. The car lit up like a x-mas tree. Go to your local sears and check your charging system. If it is the alternator, replace that. Otherwise, check your battary. Then the horrific job of checking your ground -- good luck with that one.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 09-13-2001, 10:34 AM
British Car Junky
I just got a new battery last week. I will have the alternator checked and if that's ok, I'll take the car to the dealer to check it out. If it is a tranny harness pin, I had the whole transmission replaced about 6 months ago, so they should fix that under warranty. They better anyway.
Jeff
Jeff - Tampa, FL -
Old 09-13-2001, 10:46 AM
Aredubjay's Avatar
Jeff
Jeff,
If you've just had the battery replaced, the first thing that would be suspect would be the battery connections. Make sure that all connections are secure, including the ground wire to the body that resides just in front of the battery.
Randy Johnson
Old 09-13-2001, 10:50 PM
British Car Junky
It was the alternator!
Just an update: I got stranded on the side of the road tonight after my car lost power. Freaky experience, but I'm ok! So, it was the alternator. FYI kids: If your dashboard starts lighting up, it's probably your alternator. I'll try to change it out tomorrow, provided I get the part right away.
Thanks for the help!
Jeff
Jeff - Tampa, FL -
Old 09-14-2001, 01:19 AM
Seraph's Avatar
Re: It was the alternator!
Jeff
Thanks Jeff -- for the update.
Uh... I know how it is like to be with the SVX or rather SVX to die on the side of the road...
But it sure is worth it when the baby is running
Lwin
Current SVX: NONE
Old 09-14-2001, 10:50 AM
cocacola08's Avatar
Re: Re: It was the alternator!
Anything is worth it to keep 'em running....Well unless someone hits ya and totals it, then you go buy a new one!
Kev
Old 09-14-2001, 12:14 PM
Seraph's Avatar
Re: Re: Re: It was the alternator!
God forbids!
Lwin
Current SVX: NONE
Old 09-14-2001, 12:25 PM
cocacola08's Avatar
Re: Re: Re: Re: It was the alternator!
God forbids!
Lwin
Oh ya forgot to put that on there.
Kev
Old 09-25-2001, 12:59 PM
**92SVX**
Originally posted by Aredubjay
Jeff,
Randy...quit feeding these boys lines!!!!
Old 09-25-2001, 01:05 PM
Aredubjay's Avatar
Hey, you know me. Just your average power-hungry egomaniac, schlepping out brochure speak like a 14 year old with a 1,000 horsepower SVX .
Randy Johnson
Old 09-25-2001, 01:08 PM
British Car Junky
Stretching the truth
Randy, it's a 980 hp SVX, not 1,000, so stop overexagerrating!
Jeff - Tampa, FL -
