Old 10-04-2007, 08:49 PM
mbtoloczko's Avatar
sans SVX
latest Koni/GC build-up pics
I just finished up a high-end Koni/GC build for a customer. Turned out very nice, so I thought I'd post a few pics (see below). Here are the specs on the build-up:
- Strut bodies degreased and sandblasted
- Strut spring perches cut down, washers welded on, drilled for Koni inserts
- Strut bodies primered and painted
- Strut bodies sealed with silicon sealant after Koni insert install
- New OEM SVX front strut mounts
- Additional grease applied to front mount bearing
- New performance rear strut mounts (much stiffer than stock)
- Strut mounts shimmed for proper clearance and upper spring perch support
- Spring height adjusted to customer's desired ride height
- Rear Koni inserts preset to 1/3 stiff
- GC springs 330f/280r
- Will be installing custom dust shield on front strut mount top
I'm currently discussing with the customer about the possibility of installing some strut shaft boots to help protect the shaft seal from dirt/debris.
Mychailo
Visit my locker
Old 10-04-2007, 11:20 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
how much will it be for this set?
Old 10-05-2007, 01:37 AM
Dessertrunner's Avatar
Look great do you have any suggestions for a tougher top strut mount as the standard SVX ones can't take the pounding. Had a look at the rally ones but they will be to noisey.
Tony
Old 10-05-2007, 07:39 AM
AFBeefcake's Avatar
Subaru Swapper
Nice. I allmost had a set like that, but porter messed that up
2005 Legacy GT
My WRX's Cardomain Page
Old 10-05-2007, 09:32 AM
mbtoloczko's Avatar
sans SVX
Crazypolo95: Cost is around $1675 + your old struts.
Tony: The rear mounts shown should be tough enough for offroad duty. I haven't researched a replacement for the front because they have been good enough for road duty, but I would think that one of the Gruppe-N mounts with a hard rubber bushing could be adapted. They'd be louder than stock, but shouldn't be horribly noisey like a pillow-ball setup.
AF: You never got the parts or your money back from Porter?
Mychailo
Visit my locker
Old 10-05-2007, 09:39 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Mychailo,
Very, very nice! looks like you did a little more welding on the front end link brackets (?)...can you PM me about the "sealed with silicon" and the "shimmed for proper clearance" aspects.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-05-2007, 09:52 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Great looking suspension set-up Mychailo. I'm sure your client will be pleased.
I'm looking forward to getting some koni inserts this winter for my DS WRX (will have to stay on stock springs though).
2006 Steel Gray WRX TR (sold)
Old 10-05-2007, 10:21 AM
mbtoloczko's Avatar
sans SVX
Hey Chike,
Still running in stock class, eh? :-) Have you started tuning your car with ECUFlash yet?
Mychailo
Visit my locker
Old 10-05-2007, 10:36 AM
AFBeefcake's Avatar
Subaru Swapper
It was a good thing I didn't send him any money, but he never sent my strut cores back. I was trying to be helpful and send them to him in advance so he could build the kits and I got screewed. Then a year later he told me a story and said he would send them right out. I never got them.
2005 Legacy GT
Old 10-05-2007, 12:31 PM
wawazat??'s Avatar
Yeah, I'm still around
Kinda wussy spring rates doncha think Mychailo Nice looking assembly however.
AF-If you need a set of housings, I may be able to help as I should have two complete sets from the cars I've torn down. Cover shipping and a case of decent beer and I'll get you set already gutted. Interested?
Down to none
Old 10-05-2007, 02:12 PM
AFBeefcake's Avatar
Subaru Swapper
Thanks for the offer. Normally I would jump on this, but I am broke right now and I know there is no way that I could come up with the money for the konis and GC's. It sucks.
I just hope to have the money by the time the suspension group buy goes thought and get that setup.
2005 Legacy GT
Old 10-05-2007, 02:21 PM
mbtoloczko's Avatar
sans SVX
Yeah, it turned out nice. I figured that there should be at least one more picture of a set of trick Koni/GCs on the network. ;-)
How's the handling with your spring rate combo? Seems to be a larger difference in front/rear rate than what I've seen by others. Is that rear spring 9" or 10" long?
Mychailo
Visit my locker
Old 10-05-2007, 03:33 PM
sicksubie's Avatar
The group buy is not going through it looks like
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-05-2007, 03:38 PM
Yeah since the Megan Racing is out sign me up for the Konis again. :/
I should be able to afford them sometime next year after I rebound from the 5 speed swap.
Old 10-05-2007, 05:59 PM
95pologreen
hey what kind of top mouths are those?. and how much was the set over all. Cuz i just may want some
