attaching aftermarket tranny cooler?
Hi Folks. For those of you who have installed aftermarket tranny coolers between the radiator and the a/c condenser, what did you attach the cooler to, and how did you attach the cooler? I also have the same question for those of you who have installed tranny coolers in front of the a/c condenser. Thanks!
I use the in-between mount scheme, and the Hayden cooler I use (same as a B&M) came with these plastic ties that go through the radiator fins to hold the cooler in place. It's near impossible for me to describe, but easy to see once you look at one. On each side of the cooler end caps (facing the radiator and the condensor) I have foam blocks (also supplied in the kit) that protects against metal to metal contact.
Sounds a bit Mickey Mouse, but if it works, then that's cool. :-) Thanks!
Alan 1987 928 S4 (Black) 1997 SVX LSi (Ebony) 2005 Legacy GT (Silver) 1987 928 S4 (Black) 2008 Lancer Evolution X MR (Apex Silver) 2013 G37xS AWD(Obsidian Black) 2018 Q60 Red Sport AWD (Graphite Shadow) 2022 KIA Stinger GT2 Scorpion AWD (Aurora Black) |
