Old 10-15-2003, 02:14 PM
lee lee is offline
Don't know what to call it, but want to remove it
The title says it all pretty much except for describing the part.
It's the body colored part just in front of the upper part of the trunk lid, extends forward under the back-side windows. Additional hint: the power radio antenna goes through the part.
Only part of my car where the clearcoat has worn through. Thinking about some graphic treatment until I can afford a proper paint job. Ideas?
Old 10-15-2003, 07:08 PM
Subafreak's Avatar
Superbeast
I know of no such part. But I have something similar that matches the color of my roof.
Sorry not sure how to get that off.
Old 10-15-2003, 07:46 PM
lee lee is offline
and your trunk is what color?
thanks anyway, I was beginning to feel lonely in this thread.
Old 10-16-2003, 07:50 AM
Exclamation
You need the REAR QUARTER GARNISH. Here is the link to the clips and pins needed. Garnishes are NLA
https://www.subaruparts.com/auto-par...ter-panel-scat
http://opposedforces.com/parts/svx/u...llustration_2/
They came pre-finished, but have been discontinued and NLA. However the clips are still available.
The main issue now is that 25-year-old plastic is brittle and the molded-in clip holders, in the back of the garnish, break and there is nothing to hold the clip. The intent now is to to break the clips, not the clip holders on the garnish
According to the diagram there is 1 pin and maybe 9 clips
File Type: jpg 1EAF6A7C-EF9D-4FCB-8B69-D8C97BD14764.jpg (39.7 KB, 625 views)
Old 10-16-2003, 12:44 PM
lee lee is offline
Originally posted by Green1995SVX
There is no way to remove them properly. I tried for hours on one side and couldnt do it. You cant access the inside of all the clips. Your best bet is to start at the rear (trunk side) and just give it a good yank. The clips will break, but the piece will come off.
Mike
Sounds like you might know this from experience. If so, how was it put back?
Old 10-17-2003, 11:13 PM
longassname's Avatar
Just some dude.
Significant Technical Input
I've done this as well. You have to order all the clips and the pin in advance. If i remember correctly it's 6 clips and 1 pin on each side. You'll also need some adhesive remover to clean up the rubber trim pieces and some weather strip adhesive to reattach them. Also be very careful in trying to clean up the quater garnishes before painting them; the plastic melts with pretty much any solvent. You can put the pieces back on the day after you paint but don't put the grommet around the antena on the drivers side back on for several days..maybe a week.
Old 10-18-2003, 09:14 AM
red95svx
temp fix for faded garnish
While we're on the topic of rear quarter garnish, I'd like to point out that for a temporary fix Armorall does wonders for making the plastic shiny and a little more colorful. Mine are faded pretty bad but a little bit of Armorall makes them look good for two or three days, longer if it doesn't rain.
Old 08-11-2011, 08:40 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Don't know what to call it, but want to remove it
wow, this is an old thread, but just what I needed to know.
1995 POLO LSI 76K MILES SOLD
Old 03-01-2018, 12:00 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Just what I needed also, but for breaking all the connecting bits. Any progress on this, as to the proper way to remove and reset the assembly?
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 03-04-2018, 02:05 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Pretty well any plastic polish will do the trick on this piece, my red has faded loads of times over the past 23 years I have had the car (same as the door mirrors).
I use Cherry Glaze (it is meant for paint) - it does a great job for any plastic and leave a nice smell.....
https://www.autobritedirect.co.uk/in...rotectant.html
Old 03-04-2018, 04:11 PM
https://www.ebay.com/itm/97-1997-Sub...1Z3CRN&vxp=mtr
Also check out SSP Recycling. Click on each car to see what parts are inventoried. Garnishes are available.
http://sspparts.com/cars/Subaru/SVX
Example:
PASSENGER SIDE $75.00
DRIVER SIDE $75.00
Old 03-04-2018, 08:30 PM
Her is what I found so far in the FSM and parts manual. These quantities are for both sides
PIN, Rear Guarter Garnish 96002PA000 (2)..number 1 in diagram
CLIP, Rear Quarter Garnish 91167AA000 (2)..number 2 in diagram
CLIP, Rear Quarter Garnish 96002PA010 (16)..number 4 in diagram
http://opposedforces.com/parts/svx/us_c12/type_5/body_equipment_exterior/outer_garnish/illustration_2/"]http://opposedforces.com/parts/svx/u...llustration_2/[/URL]
Old 03-05-2018, 09:41 AM
Yeah, I see all that, but it ain't that easy. Is it accessible through the back seat from the inside?
The Worm
_______________
No Mods, 33K Miles
Old 03-05-2018, 10:42 AM
theflystyle's Avatar
From what I recall it is not accessed at all from the interior of the car.
1994 SVX LSi
2008 Legacy 3.0R
Old 03-21-2018, 06:08 AM
That's y I had them paint them in place when I had car painted.
