Ok so I'm working on a 5 speed swap and ran into a couple problems
1st-the previous owner I purchased it from had already done the swap and the speedometer does not work and I was wondering what's the best way to wire the speed sensor 2nd-options to wire up the reverse lights as well 3rd-the dash lights do not work but the gauges work for the most part there is a big wiring mess under the dash. Does any one have a component location diagram to help I'm assuming that it has something to do with the rigged ignition switch with missing wires 4th-kind of unrelated but has anyone had problems with the rack and pinion leaking from the threades for the lines, I replaced a couple pinched lines and now power steering works but will leak out all the fluid daily quick (didn't work when I got it) Long story short it was a poor instal from the previous owner and now swapped in a new transmission after the other one failed and kinda stuck at the point I was when I bought it. The transmission is out of a 03 Impreza RS any help would be appreciated |
Re: Speed sensor/ speedo??
Get a hold of Phil (kingbobdole I think is hi name here) he has 5-speed swap experience, and wiring, general SVX /Subaru knowledge (he is in CO)
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
