Old 03-20-2017, 12:30 PM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
Smile How to solve the problem with oil leak on the top of motor
Problem: oil leak on the top of the motor
Reason (in that case): Oil is coming from ventilation system through PCV valve, then accumulating in the bottom of the intake manifold, then drips from the I.R.I.S. valve shaft when the valve is open.
How to solve: install oil catch tank
What to buy:
Instruction:
1. Remove intake manifold
2. Remove old PCV valve
3. Clean intake manifold inside to remove all oil from the bottom
4. Clean the top of the motor
5. Install new PCV valve
6. Measure hoses lengh to cut
7. Install oil catch tank
8. Install hoses to PCV valve and to crank case out pipe
9. Install intake manifold
10. Plug hoses (or hoses and adapters) to oil catch tank
11. Enjoy!
Subaru SVX LSi `95
Old 03-26-2017, 11:25 AM
JENKIN's Avatar
JENKIN JENKIN is offline
Palm Springs of Washington
Re: How to solve the problem with oil leak on the top of motor
nice install, and great write up. kudos.
if either one of my cars were up and running I'd take a look at this.
but I do appreciate the work involved
Old 03-27-2017, 11:21 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
That is superb work on the write-up. Thank you for providing pictures, those help a lot.
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
