Old 12-13-2014, 08:32 PM
kjoyes kjoyes is offline
Found this product for fighting Rust
http://www.corrosionx.com/corrosionx.html
amazon has it here
http://www.amazon.com/Corrosion-X-An...pr_product_top
Old 12-13-2014, 11:09 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Found this product for fighting Rust
Basically the same stuff used by Krown. Yes, it works. Krown has the application down to a science.
Tony
Old 12-14-2014, 01:20 AM
bheinen74 bheinen74 is offline
Sort of reminds me of Gibbs Spray
http://www.gibbsbrandlubricant.com
not sure though, but I think the post is a knock-off of Gibbs.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 12-14-2014, 01:30 AM
K so it works I have rear quarter panel rust, that need body work. But I want to slow the rust so it doesn't get any worst.
threw out the years I have found many product that prevent rust or stops it.
here are some options and give you opinion on them including to corrosion-x
here are the other aerosol spray options
seem like they have a science to it and they don't mess around buy coating a car unnecessary
LPS 3®Premier Rust Inhibitor
http://www.lpslabs.com/site_files/te.../TDS_00316.pdf
lps is more of a waxy type that I used in the inside of my door panels and inside if my quarter panels and under the car as well.
Con of this product it adds weight to the car. because it is a wax and it not a film. Notice the only plus side of adding weight is when I close my door it make a clear clunking noise and doesn't rattle like rice sound. but I hate adding weight to a weak trans.
these are paint-type on options I would say they add weight as well but it is for really bad rust work best under or behind a panel of a car and not a painted panel surface.
por-15
http://www.por15.com/Rust-Preventive-Coating_c_11.html
rust bullet
http://www.rustbullet.com/
They have a product called rust bullet black shell that I think would work great for coating the under carriage/ wheel wells of our cars.
http://www.rustbullet.com/products/t...lackshell.html
DONT GET THESE ON YOUR SKIN......
Old 12-14-2014, 01:52 AM
DONT GET THESE ON YOUR SKIN......[/QUOTE]
TRUTH… or your clothes you want to keep. POR 15 NEVER came off an old sweatshirt of mine, and it took 1 weeek to come of my arms, My hands, took about 2 weeks…. That was when I did the entire underside of my 85 BRAT.
after 7 years on the BRAT, it is peeling off, but my BRAT was 100% rust free when applied to it. Was CA BRAT. Since, it has some small rusts. So POR 15 peels after 5-7 years…It peels off like when you get sunburned and PEEL
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 12-14-2014, 03:24 AM
Will use this when I resume my Mercedes project in the future.
Old 12-14-2014, 07:03 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I have used many products that claim to stop rust, including the ones mentioned. Rust is a cancer, it always comes back unless you cut it out.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 02-10-2015, 08:39 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Here is an Aussie solution to fight rust.
https://www.youtube.com/watch?v=uJEXNvRFMaI#t=293
Gene and Ben
Old 02-12-2015, 06:40 PM
immortal_suby's Avatar
Thread Killah
I fought rust by moving south after the little red wagon broke in half at the firewall. Seems to have worked!
Locker Link
2015 BRZ Limited 6MT
