Cutting The Wire To Solenoid "C"
I have my car at a transmission shop to get the rear wheel drive fixed. The rest of the transmission is working okay but not the rear wheel drive.
Has any one ever had just the transfer case removed from their car and repaired? The service manual says this can be done and I wanted to know if it could really be done. Last edited by svx_commuter; 08-30-2001 at 07:12 PM. |
Well I just called the shop and there is no line pressure in the transfer case. Does this sound familar to any one? He says it may be a problem with the TPS not being picked up by the TCU.
Re: Transfer Case Removal
2. The extension housing can be removed while the transmission is in the car. (That's where the transfer clutch assy lives.)
Pull my finger! |
I'd more likely suspect either a plugged orifice, (someone may have had the FWD fuse installed too long), or an open circuit in the transfer solenoid circuit.
Pull my finger! |
Do you have the blinking power light when you start the car?
Have you looked at one of the FAQ's to try to pull what the error codes are yourself? Might give you an indication as to what the problem might be. Chris/Sith: If I were to make .mpg's or step-by-step with pic's of the tranny code retrieval, check engine light code retrieval, or anything else simple (I'm open to suggestions here), could you host it here, maybe under a D-I-Y'er section? VK Quote:
The transfer clucth is operated by duty solenoid "C" and the way I understand it if the power is off to solenoid "C" the car is supposed to be in AWD. Or am I missing something? I was planing on disconnecting the the wire to "C" from the TCU to check this out. Clogged orifice where? Still in the transfer case? or in the hydraulic control valve unit? Is there any easy way to check for this and maybe a way to flush it out without removing the transfer case? |
I have checked for transmission codes and the car does not have any. It says that everything is okay.
If there's no power to the duty solenoid C, the car will run 50/50 split all day long. I know this from experience. In fact, I still have the solenoid with the wire to it "fallen off".
I would doubt the TPS as the cause of it, as there is at least 10% power going to the back at any given time. If the car is on a hoist, the rear wheels do not spin at ALL? VK Quote:
The wheels will spin until you look straight at them. Then the resistance from your line of sight stops them. No, seriously, they do not spin for long and can be stopped with a touch.
You say the wire fell off. Isn't the wire and solenoid inside the transfer case? I guess your power light said the car had a fault? Can you say what the car was like with the 50/50 split? Great traction but 12mpg? Quote:
The wire was inside the transfer case. 3 or 4 hours labour, one solenoid, 7 liters of Castrol synthetic fluid (they dumped out my old tranny fluid, which was 3 month old Redline Synthetic! ), exhaust gasket, and $550CDN later, it was fixed. They saved the old part for me, so now I have a $100 paperweight.
Someone need a Solenoid C? Slightly used? Only needs a quick solder job... 12mpg was about right. Mileage was HORRIBLE. And to top it off, it was just past Christmas, with snow on the ground. On dry, every time I made a turn the thing would bind. And on snow, every time I made a turn, just a slight throttle blip would cause the tail to swing out wildly. Believe me, it's much more fun doing 4 wheel drifts on snow with the system working properly. Never had so much fun on snow with a car! Back to your problem. If the rear wheels spin, that's good. It doesn't take much to stop any one of the wheels with the car on the hoist. And once the wheel's stopped, I don't recall seeing it spin up on its own unless one of the other wheel was affected. What happens with the hoist on the car, stop the rear wheels, then stop the front wheels? Does the rear wheels start to spin up? VK Quote:
When I picked up my car yesterday, the man said "No pressure in the rear section" He even tried it on the grass. Broke the front wheels loose but not pressure in the transfer section even under heavy acceleration. He managed to get the bottom and side of the car caked up with dirt and grass and left two wide grass-less patches in the lawn! BIG fat SVX tire WIDE grass-less patches! He says there is an electric problem. So........ I am off to track that down. I figure I will check the voltage to "C" at the connector by the TCU. If the voltage never goes off I am going to disconnect the lead to "C". You know? You just reminded me of something. Where does the car get the signal from to tell the transmission that it is in a turn? Your experience says that when the car is in a turn the rear wheel drive backs off. I think this is because of the LS rear end or is it the same in all Subaru's? |
There have been people disputing whether the ABS sensors come into play with the AWD, but from the service manual, there was a mention that the ABS sensors are used to sense a turn as well.
I somehow doubt that as well, because I've pulled the ABS fuse now for 6 months, with a busted RR ABS sensor, and even in tight turns now the transmission does not bind. Maybe there's an inertia sensor somewhere in the ABS system? I don't really know, it's just a guess. If you disconnect the solenoid C power wire, you should have 50/50 split all the time. If you do, I would assume that the AWD physical components are working, and it could be an electrical issue. If you don't have 50/50 after disconnecting the wire, I guess it would have to be a physical problem? I dunno, just a guess. Eddy?? VK Quote:
ABS Sensors & AWD
The ABS wheel sensors have absolutely nothing to do with the function of the AWD. AWD is determined by the differential readings between speed sensors 1 & 2. Both of which are taken from the transmission.
However, after having read up in my copy of Road & Track, I think there may be a relationship between the ABS wheel sensors and the passive AWS.
Pull my finger! |
Re: ABS Sensors & AWD
Hey, I'm just quoting the information out of the genuine Subaru SVX repair manual. Like I said, I doubt that as well.
I guess Fuji must have gotten Cletus-san to write that particular section. VK Quote:
Re: Re: ABS Sensors & AWD
Pull my finger! |
