our car is on here?!
http://tbcwheels.ridestyler.com/?mode=webtk
just thought it was kind of interesting to see our car with any kind of rims we want ![]()
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: our car is on here?!
That Is awesome. i could play with it for hours. I want this!!!!!!
I think our cars look nice and menacing tinted, and lowered. |
Fun to play with but I'm so picky I couldn't find a pair of rims I would want to buy and put on...
1994 subaru svx le 112k |
how would 36mm offset work? would it effect the handling?
offset is how much the rim centerline is offset from the hub face. Stock is +52mm IIRC. This site is clearly pedaling Nissan/Mitsu fitments that are not going to fit and drive any where near as nice as using the OEM offset.
If you want to get the right rims, I use a search for 2005 STi rims as it uses the same bolt pattern and offset. Also the sites like tirerack or wheeldude seem to limit it to widths/offsets that will fit in our fenderwells. Dunno if the same would be true if you searched for 2008+ STi aftermarket rims. Oh and NEVER listen to stancenation people on wheel or tirefitment. FOR ANYTHING. Rarely listen to autoX STi owners, they can get a little insane pushing the very last mm of tirewidth which might not work for your SVX. |
Gene
My favorite was the DIP Laser D95. This car is of Italian design on the outside and Italian body styles scream for star shaped 5 spoke wheels.
yeah i love these 5 spoked wheels but i guess the offset 36 will not work well with the svx, any other similar rims with a more natural offset for the svx?
http://www.wheeldude.com/catalog/ind...Path=90_217_91 These will work on your car with correct offset and hub bore. Try NC miata (2006+) or RX8 for a few more options that are close in offset, but don't have correct hub bore. Sometime I want to try 2002+ explorer rims for fitment. Not too expensive used and most should be in good shape with the fat squishy tires protecting them from curbs and potholes. Last edited by XT6Wagon; 08-17-2011 at 01:45 PM. |
Where was this like 10 years ago
