Old 01-10-2011, 08:04 PM
michael's Avatar
michael michael is offline
What Potholes ???
Locked out :( "Trunk related"
My friend locked something in his trunk the other day and can't get it to open. All he has is the valet key and the dealer can't cut a key based off the VIN. The lock on the back seat is locked. Is there a way to jimmy that lock? I don't want him to have to drill the lock on the trunk. Any other suggestions?
Wanted: Steering Wheel
Old 01-10-2011, 10:06 PM
Cam Cam is offline
Re: Locked out :( "Trunk related"
It would be cheaper to have a locksmith come out than replace the lock...most likely.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE .256 duration intake/exhaust cams
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 01-11-2011, 07:36 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
It's very hard to get into a locked SVX trunk without a key.
I suggest trying to pick the lock before drilling it.
Take a piece of thin stiff wire and bend it into a U shape like a hair grip and insert into the top and bottom of the keyway. Use this to apply a constant twisting force to the lock barrel. Then take a straight wire, push it all the way to the back of the keyway, tilt it and pull it out so you can feel it stroking the wafers as it moves.
Do this a few times. If no luck then release the twisting force so the wafers click back into place and start again. Repeat until you get bored and then resort to the drill.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-11-2011, 07:51 AM
RSVX RSVX is offline
Network Design Administrator
Since I see no mention of it, I am guessing that the trunk release on the floor is disabled, too?
Life is a game. Play to win.
Old 01-11-2011, 11:55 PM
My exact question. The other thing is that they should be able to cut a key.
Old 01-12-2011, 05:03 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I've heard that if the dealer that originally sells the car doesn't properly register the key to the VIN in SOA's system, that you'll never be able to get the key cut with the VIN.
Another option is to take the passenger door apart to get the key code of the lock cylinder on that side.
Old 01-12-2011, 05:50 AM
michael's Avatar
What Potholes ???
The lock on the trunk itself has been set so it can't be opened from the lever in the front. I guess the vin was never properly registered because they said they can't do the key from that. Dave, you mention a key code? would it be on that usually corroded lump of lead called a lock cylinder? They can do a key off that? I'll let him know. No possibility of quickly unlocking the back seat? I don't think I have the skill to pick the trunk lock btw.
Old 01-12-2011, 06:19 AM
Hocrest's Avatar
Yeah, there is a code on the passenger cylinder. This is the same code stamped on the master key.
Why not try "breaking in" to your trunk. Have someone in the trunk with a flashlight, while you work in the back seat to see if there's a way to do it.
Old 01-12-2011, 02:40 PM
ZMan's Avatar
ZMan ZMan is offline
UH - Have someone in the trunk???
Old 01-15-2011, 04:32 AM
Marcus Marcus is offline
Did you try both sides of the back seat, they have separat look switches (you would be extremly unfortunate to have all three of them - this is including the drivers seat release lever - in looked position at the same time).
In case you do, it might be easier/cheaper (than fumbling with the door locks) to get a spear tail light from ebay/other member/yunk yard and smash the one at your car. This should give you as much access to the trunk as needed to move one of the rear seat levers back into unlook position.
Good luck!
Marcus
Old 01-15-2011, 08:37 AM
Old Fogey
His car is a '92 Marcus, thus no split back seat.
Glenn
Old 01-15-2011, 01:52 PM
michael's Avatar
What Potholes ???
I't not my SVX but it is a 92 w/o split rear seat. I'm going to pull the pass. lock cylinder, it's much easier than one would think.
Old 01-16-2011, 02:49 PM
michael's Avatar
What Potholes ???
We took the lock out today and took it completely apart trying to find the code. I pretty sure we could have seen the code while it was still in the car. Not sure if this is it but I'm hopeful. We will see tomorrow when the dealer opens. I attached a pic of where I think the # is.
Old 01-16-2011, 04:01 PM
Old Fogey
Looks like you're on the right track Michael. I just checked lock cylinders and keys from my '93, and the numbers match.
Glenn
