Acceleration Control
Author: Subaru NUMBER: 11-44-93 DATE: 10/04/93 APPLICABILITY 1992 AND 1993 SVX SUBJECT: SVX ACCELERATION LOGIC CONTROL The SVX ECM has a built-in logic which controls the vehicle acceleration from a standing start. The logic controls the power during light to medium acceleration. THIS CONDITION IS "NORMAL", and no repair attempts should be made to change it. This condition is sometimes mis-diagnosed as a hesitation. If a customer complains of a hesitation and it is not the normal condition as described above, make sure the customer is using premium fuel. A check of all basic engine functions should be performed to make sure they are all normal. If all engine functions are found to be normal, follow the procedures below. CAUTION: BEFORE WORKING ON THE ECM, REMOVE THE STATIC CHARGE FROM YOUR BODY BY MOMENTARILY TOUCHING AN EARTH GROUND, SUCH AS: A COLD WATER PIPE, METAL BUILDING SUPPORT BEAM OR A CLEAN, METAL AREA OF THE VEHICLE. 1) Remove the ECM from the vehicle and remove the six screws securing the cover of the ECM. NOTE: If the ECM has a ROM installed into the ROM socket, the tan resistor should be cut and/or removed. (See Service Bulletin 02-87-92). 2) Locate the black noise suppressor as shown in Figure 1. 3) Wrap the noise suppressor with electrical tape. CAUTION: SAFETY GLASSES MUST BE WORN DURING THIS PROCEDURE. 4) Holding the ECM upside down or on its side, grasp the black barrel shaped portion of the noise suppressor with needle nose pliers. Slowly squeeze the noise suppressor until the barrel shaped portion is crushed. "DO NOT USE A TWISTING MOTION." Be extra careful not to cut the wire which runs through the center of the suppressor. If the wire is cut or broken the ECM must be replaced. 5) Holding the ECM upside down, remove the tape from the noise suppressor and lightly shake the ECM to make sure all the crushed particles are out of the circuit board. NOTE: IF THE ECM DOES NOT HAVE A ROM INSTALLED INTO THE ROM SOCKET, DO NOT CUT THE TAN RESISTOR. 6) Reinstall the ECM into the vehicle, and clear the memory using the select monitor. A modified ECM will be incorporated in production beginning with 94MY vehicles. Modified ECMs can be identified by a black dot next to the parts number label. FLAT RATE INFORMATION This operation can be claimed under the Subaru Limited Warranty, if applicable, using the information: Last edited by How-To Doc; 04-20-2010 at 12:07 AM. |
