HELP! stripping torque converter bolts!
im trying to remove the 4 TC volts through the access hole, but no matter what, the wrench/socket just skips off! on all 4 bolts! 1986Nate suggested extractors, and thats my next shot after work tomorrow, but im afraid i wont have the room to get them on the bolts and get a wrench in there along with them. any other ideas, just in case that doesnt work?! im kind of lost here, everything else on the stock trans removal has been problem free, except for this
Re: HELP! stripping torque converter bolts!
If you pull the alternator and use a long extension, you can put more force against the socket. If your not already using a 6 point socket and the bolts aren't too damaged, switch to a 6 point.
Costco sells really great "box end" ratchets, in sets, that are tougher than you think. You can use a cheater with it also, just keep it all the way on the bolt!
Keith ![]() |
thanks a bunch guys! Turns out 1986Nate actually sent the extentions tip but i didnt notice it on my phone. luckily, my alternators already out! with luck, by tomorrow night the trans will be in, only needing to rebuild the cv's, and hopefully get the beads on the stock rims fixed to get it on the road!!
YEAH! So excited! |
Special Thanks to Our Friends and Sponsors: * ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
i was having that issue too but i somehow using a 12point socket got enough grip for me to get it off
mmhmm i actually replaced the bolts with bolts from the oilpan bolts from my friend's 4Runner. works like a charm.
oh, update, i went to my moms for my lunch brake, and used extensions under the manifold. worked like a charm! i didnt eat till i got off work that day, and i was really hungry, but i was satisfied that there were no problems removing them in the end!!
This is THE WAY to do this! ![]()
