Old 08-13-2009, 07:48 PM
wyldnwoody44's Avatar
wyldnwoody44 wyldnwoody44 is offline
Mechanically worthless Man : )
Dome Light Question??
Hi all, I got into my car tonight and my dome light would not work. It wouldnt work with the button by the sunroof or by either door. All the other lights work fine in my car. Occasionally some random lights go out but nothing major and not that often. I have a 3 pack of bulbs and tried a new one, that wasnt the fix. Anyone have any ideas? Thanks
-92 Ebony LSL, complete with all the problems
-New self paint job; charcol metallic silver
-4.44 tranny,
Nicknamed the SexVX : )
Old 08-13-2009, 08:24 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Dome Light Question??
Did the spots work?
Old 08-13-2009, 08:29 PM
yep the spots come on no prob
-4.44 tranny,
Old 08-13-2009, 08:50 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Thats weird, the dome light switch (room, door) gets power from 2 seperate sources, fuse #25 and the time control module. They also share a ground with the spots, so the ground is good.
Try turning on the ignition and headlights, and pressing the "door" switch with the doors open.
Ive been eyeballing the wiring diagram and the only thing I can suggest is to remove the dome light cover and manually check for voltage across the terminals. You might have to remove the dome light assy if there isnt any, and look for a loose or broken connection.
Old 08-13-2009, 09:20 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Try another new bulb. I put a new one in there and it turned out to be bad.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-13-2009, 11:28 PM
subiemech85 subiemech85 is offline
just because it's NEW doesn't mean it's GOOD
I replaced the OLD BROKEN, end came off, with a GOOD USED bulb from a nissan maxima wagon cargo bin lamp, remembering what it came from as I type is sweet!
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic
click here for fuelly mpg info
Old 08-14-2009, 12:02 AM
Check your sun visor. If one of the little wires is broken, all kinds of things go goofy. Good luck.
Old 08-14-2009, 12:02 PM
Thanks for the input. I pulled one of the spot lights out and swithced them around and now everything seems to be working fine. Damn Wal Mart and their bargain lights...its a slippery slope
-4.44 tranny,
Old 08-14-2009, 01:02 PM
Good to see you got it fixed anyway.
