Rear Diff leaking
Well I had my car on the lift today and noticed the cover is leaking, passenger side axle seal, and the seal on the rear of the diff towards the driveshaft. So what all seals and/or parts should I replace when I take it out besides the seals mentioned above.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: Rear Diff leaking
That is every possible place for it to leak from! Who has been inside your diff? I have never, ever seen a subaru leak from the input seal. Hopefully you just have to remove the flange to replace it, just don't forget to re stake the nut. Keep an eye on this and repair as soon as possible as the unit only holds .4 qt and loss of half of that amount will cause it to be destroyed.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
The input seal leaks as I noticed oil flung around the U joint on the heat shield above it. The axle seal isn't dripping but wet, and the rear diff is seeping but not enough to drip on the ground. Is it pretty easy to remove the diff? I want to remove it myself and take it to work and have the Subie tech look at it to help me with the seals.
Bump on how to get this thing out easy.
