Failed Smog...
'92 SVX 109,000 mi,. orig OEM exhaust/cats. Failed the idle test, excess hydrocarbons. Technician suggests replacing main cat. Fresh air filter, plugs replaced last year. Do I need a new cat? What do I need to do to pass?
Thanks, WGJ |
It could be the cat, as I did everything else within economic reason to my Nissan 240SX, with over 220K, & it still failed - three times!. As a last resort, I replaced the ORIGINAL cat, & the car became greener'n a Prius.
My '92 SVX with about 130K somehow passed with all original everything, except plugs & PVC valve. Just be sure the car is REALLY warmed up (drive it over 20 miles) before re-taking the test. In my home state of Merryland, if you spend 450 bucks attempting to cure the problem, you get a 2 year reprieval. I hope Ah-nold is equally forgiving. ![]() Good luck, Ron.
Good s**t happened. ![]() '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. Last edited by Ron Mummert; 11-30-2006 at 07:50 AM. |
Our silver with 176,000 failed first attempt, but hadn't been run for a couple years, and still had some old gas in tank. Ran it out, bought some 'Emission Test for dummies'-[injector cleaner] and followed directions. Passed easily.
Special Thanks to Our Friends and Sponsors: * ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Re: Failed Smog...
My friend suggested O2 sensors, so I sent for 2 @ SubaruParts.com for $240 with S/H...Yikes! I wonder if I wasted my money on those...maybe shudda bot a CAT!? Thanks for any help you can give...I'm stumped right now! ![]() ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
