Old 03-03-2009, 01:09 PM
zavikan zavikan is offline
Send a message via AIM to zavikan
S/C on the lil old slushbox?
Im looking seriously at the S/C's for sale currently. Unfortunately the cost *ugh* makes for sacrifices as well. I will certainly not be able to afford a M/T for quite some time if I get one of these S/Cs.
My auto runs perfectly strong, and has a cooler in the front. Is it going to blow up on me (spirited driving, but not abusive).
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 03-03-2009, 01:47 PM
sicksubie's Avatar
Re: S/C on the lil old slushbox?
I had my AT for 5 months of very spirited driving and it held out just fine. It had been rebuilt about 45k prior though...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-03-2009, 02:04 PM
bheinen74 bheinen74 is offline
the slush box is limited in what it can handle on transferring power from the crank to the axles. It will fail, even sooner with a S/C.
Not a big problem tho, just figure out how to rebuild using a master transmission rebuild kit, do it yourself, not that expensive.....
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-03-2009, 02:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
it all depends on how "spirited" your driving will be, post s/c install
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-03-2009, 05:40 PM
it all depends on how hot the transmission gets. More power passing through the trans means the amount of heat it will generate will increase proportionally. Watch your temps. Otherwise weak points are.... Front diff, and trasnfer drum. Transfer drum will likely fail first shortly followed by the front diff case
Old 03-04-2009, 07:19 AM
end of this thread will be by first the thread starter, posting FAIL of tranny. Fail
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-04-2009, 07:44 AM
hahaha. that WOULD be hilarious. hehehe.
This is a preliminary investigation into the S/C. It has not occured yet, so dont hold your breath on my dead transmission.
I am getting a bit disheartened in my questioning for the S/C though. it seems to me that it might be made more for the 'tuner' type, then some one like me, who just wants it to be installed, and then almost 'forget' about it.
$$ (within reason) not really being the choking factor, but reliability, ease of use, and low maintenance.
James
Old 03-04-2009, 05:08 PM
I think I can finally say that mine is low maint. Then my manifold got all fudged up by our old powder coaters. Making a new manifold and it should be simple after that. Just change the belt and change the blower oil regularly and thats it
