help: legacy wont start
please help, my car was put all back together with new headgaskates and now it wont start!!!! timing is right, pulled out 2 plugs and its sparkin, it smells like fuel is bein supplied. when trying to start it, it clicks about 7 times and fires one time and clicks about another 7 and then fires one time.....
Re: help: legacy wont start
starter? battery? ~
ignition cables/coil packs? loose wire to starter?
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
all marks were lined up when the belt was put on... notch to notch on all three of them...
well the map was running with no filter for a very long time. but i put one on and cleaned it with maf cleaner well the spark plugs are working fine cuz i took them out and watched them spark, and when i took them out they smell like gas bad. these are new plugs and on cylinder 3 its already black! the 3 others are still clean tips i switched injectors 1 and 3 and nothing happend, i just switched 2 and 4 and havent seen what happend yet. i also cant hear the fuel pump turn on... there is no sound from it at all inside that car even with the back seat down since it acts like before i fixed the gaskets there was a time when it did fire up and i did test drive it. the shop tech had me start it and it started and died, then he told me i have to give it gas so i started it then gave it gas then he said"its not firing on all cylinders" so he reved it up a little more and then it had a cleen idle.... then drove it for like 1 min, let the car sit for 2 weeks and it will not start at all then thats when i started doing the new headgaskets any ideas from the info given? |
its alive, alive i tell you! it was the timing, my buddy put the timing belt on way off! this thing runs like a champ now!! except the fact that i have no brakes!! i need some help on what to look for on why i have no power brakes... the abs light isnt even on...
No brakes as in no brake assist?? Or just none at all.......
If the pedal feels soft or just goes to the floor you need to bleed the air out starting at the rear wheels first (in order from farthest from the master cylinder to nearest last). If the pedal is solid but you have to press really hard to stop, check the vacuum line to the brake booster, which is the usually black round thing behind the brake fluid reservoir. This needs engine vacuum to power your brakes, maybe a vacuum hose (usually big for brakes) wasnt connected properly after the headgaskets were done, starving the booster of vacuum. Good luck! |
the brakes are really hard, i checked the vacum line and its on there correctly...
Then you have it narrowed down at least, if you have to press really hard to stop then your vacuum assist isnt functioning. IF it worked prior to the head gaskets then check and re-check the vacuum line configuration at the manifold. It might be connected to the booster but not connected properly (or plugged up somehow) at the engine side. Start the engine and pop the hose off the booster to see if its pulling in air..... if it is then maybe the booster went bad....which is kind of rare. Im thinking its a problem with the vacuum connection or config at the manifold. Good luck
booster line has a check valve in it... Try turning the line around
![]() Tom |
to my post count and to what he said.
1991 xt6 eg33? 1993 gc track car |
