Recently my 92 SVX has been intermittently running rough, usually when cold at idle, and more often when accelerating, I checked code and it gives error code 37 (lt sd o2 sensor). Could this be causing the problem? If so where is it located?
Thanks |
Re: Code 37
![]() Located where the twin exhaust pipes come down from the motor and straightens out horizontally right below the transmission. Pretty easy to get to if you have a totally flat body or a floor jack and jack stand, and a couple of blocks for the rear wheels There are 2 one for each side and I think 37 is the one on the left side. It is easily changed because the quick disconnect electrical connection allows you to disconnect the 02 wire connector and drop it down, slip a big box end wrench over the wires and screw it out. May need some kind of rust buster, but probably not! Let us know if it works for you! Keith ![]() Last edited by kwren; 08-03-2008 at 12:48 AM. Reason: added more stuff |
Re: Code 37
