Could someone give me some part numbers please?
Hello everyone.
Well its time. We are going to order everything I need to reseal the engine, and I have all of the part numbers for the valve covers. However I need the numbers for the front and rear main seals as well. I know the rear is bad, but while Im doing this, were also going to do the front. So I need those numbers to order everything. (are there how to's for both of those, like the valve cover replacement one? That is going to save my life!) Also, what else do you think I should replace while Im doing all of this? We will more than likely do the belts, as my AC squeals like crazy, along with power steering. Its really only on cold starts, but still its annoying. I would like to do the timing belt too, but from my understanding, its pretty expensive. (Keep in mind I am also having a rear wheel bearing replaced ![]() For now, that is all I can think of. If anyone has any other opinions on what I should replace, please chip in. I am trying to get everything fixed so I can have some peace of mind for a while.... -Dennis
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 |
This is the link to the parts lists. They are in the How-To Docs and should help you on the project. Good luck.
Hey um, I dont exactly know what Im looking for
![]() ![]() Think you could point me in the right direction? Thanks
This is what you need to do the valve cover gaskets and the front and rear main seals.
13270AA031 Gskt Rocker Cover Rh $20.95 $15.96 13294AA020 Gskt Rocker Cover $7.95 $6.06 13294AA030 Gskt Rocker Cover $7.95 $6.06 13272AA031 Gskt Rocker Cover Lh $20.95 $15.96 13293AA011 Gskt Rocker Cover No $7.95 $6.06 13293AA020 Gskt Rocker Cover No $7.95 $6.06 13271AA051 Wash Rocker Cvr $2.95 $2.25 (20) 806786040 Oil Seal $11.37 $8.66 (rear main seal) 806733030 Oil Seal $7.17 $5.46 $5.46 (front crank seal)
Thank you!
I just ordered all the seals, along with spark plugs, and a new intake from Dale! So what else should I do while im working on stuff? Like I said, I will be doing the fuel filter, but I dont know where it is, lol. I assume its somewhere up in the body under one of the doors? Thats where it was on my focus at least. Thanks everyone, I will let you know how it all works out! -Dennis
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 05-26-2008 at 02:24 AM. |
Just order a fuel filter...
Be a little careful with taking the hoses off... there is fuel pressure in it all the time. Keith |
The fuel filter is that shiny piece with many small hoses, nestled between the curved portion of the coolant reservoir and in front of the strut tower. To the right of the brake fluid reservoir.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
My filter is located on the strut tower next to the master cylinder
my point exactly
Could someone please tell me if this is a good kit? I dont know when the timing belt was last replaced, but one of the back covers is broken, and I got the new one to replace it, but the belt has to come off. Is this kit worth it? Are these good people? Also, how difficult of a job is this? Thanks
http://cgi.ebay.com/ebaymotors/1992-...spagenameZWDVW What about this one? Its on sale, and I would like to save as much as possible... is it the same kit? http://cgi.ebay.com/ebaymotors/92-97...spagenameZWDVW
I would not worry about either one. They both have good feedback and lots of sales. I have heard from many that this is a good kit. I haven't gotten one yet, but one of these days I should to have in case I need one.
Re: Could someone give me some part numbers please?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
Item: Valve cover gasket, svx, outer, right - 3.3l, svx Price: $12.41 Tax: $0.00 Qty: 1 Total: $12.41 Item: Valve cover gasket, svx, outer, left - 3.3l, svx Price: $12.41 Tax: $0.00 Qty: 1 Total: $12.41 Item: Valve cover gasket, svx, inner, right, no.1 - 3.3l, svx Price: $5.82 Tax: $0.00 Qty: 1 Total: $5.82 Item: Valve cover gasket, svx, inner, right, no.2 - 3.3l, svx Price: $5.82 Tax: $0.00 Qty: 1 Total: $5.82 Item: Valve cover gasket, svx, inner, left, no.1 - 3.3l, svx Price: $5.82 Tax: $0.00 Qty: 1 Total: $5.82 Item: Valve cover gasket, svx, inner, left, no.2 - 3.3l, svx Price: $5.82 Tax: $0.00 Qty: 1 Total: $5.82
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Good to see that at least some parts are coming down in price over the years.
