Help with false center light
Okay, I got in a minor accident the other day... truck in front was fine, and at first glance I was okay too. Well I'm not.
The false center light has been pushed backward from the bottom, exposing the metal frame behind the bumper and making it difficult to open the hood (because the hood latch hits the plastic "grille" section of the false light). How do I remove the grille? I tried releasing the tabs on top and pulling but it won't budge. |
remove grille
put a screwdriver between the grill and the bumper and carefully pry up on the grill to release the 2 bottom tabs
1 tab on each end they're in rubber bushings and very very tight
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
That could be a serious problem. Seeing as the impact drove the light down and back. I can't really get a screwdriver under it.
Am I stuck? Do I really have to break the part to remove it? ![]() |
First you have th eget the top tabs loose, then it will pull straight up...just takes some force if it's not been off before.
Figured it out. The light was caught on two bolts. I wedged screwdrivers under the light where the bolts were and pushed up, and it popped back up. I then removed it to inspect the damage.
Looks like I need a new center section. ![]() Thanks for all the help, guys. ![]() ![]() ![]() ![]() |
Did you post in the Parts wanted section for a new center light? Good luck on the project.
new grille
Since you need to replace it anyway ...
I'd go for the 97 grille look which is available for around $130 btw ... I put red vinyl on my original waterfall grill and then added some gutter seal for that stainless mesh look wish I knew how to paste a pic to the message I would show you
grille pics
ok
I'm going to try it ![]() ![]() hope it works
dang it! just the links showed up
Get an address for just the image itself, it should end in ".jpg", then when posting, use this icon ![]()
![]() Maybe you can place the center grille in the tabs and not put the plastic tabs. Dustin (odepaj) has one of his SVX's like that. It seems the hood prevents the grill from lifting and getting out of those tabs so its been working well for him. I considered removing the clips from my grill just so its more accessible. Good luck and take care,
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
Hocrest
thanks for the advice It wouldn't work with rogers yahoo so I decided to scrap their hosting and go here http://allyoucanupload.webshots.com ![]() waterfall grille with red vinyl and gutter screen fitted ![]() waterfall grill with red vinyl on and before mesh was added
oh ... ignore the cracks on the bumper
they're not mine ![]()
waterfall
i have an extra waterfall grille laying around from replacing mine with the 97 grill... its yours if you want it for just the cost of shipping...
