Bad gas milage
another question it has been braught to my attention that 16mpg is not good for my svx awd, andy ideas ive changed the air filter, fuel filter? plugs?
car runs like a top not sure hwat to do!
---Travis--- |
cars101 spec page has (for a 92 anyhow) Fuel economy: 17 city, 25 highway. 16 is normal. Better than I get, that's for sure.
Dan M. Barcelona Red '93 AE #073 of 301, 168k miles. |
i have a 95 mabie its fine who knows!
---Travis--- |
If you're really that concerned about it, replacing the knock sensor and O2 sensor may help you out a bit. It also helps to not drive it like you stole it.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
" It also helps to not drive it like you stole it."
How do you know he does this LMAO! I know thats kind of a given right? ![]() ![]()
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
heeh well i kinda do my transmision has been replaced 3 times the last time i meet a guy here in iowa that is reaaaaaaaallllllly good he knows his svx trannys we beefed it up havnt been able to break it yet fingers crossed been 4 years now, when do you guys/gals think the fuel filter needs replaced? its the easiest fuel filter ive EVER seen to change cept for my lawn tractor
---Travis--- |
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
50/50 split highway and city not romping on it i like to go quick but not ever over about 3 grand on the tach, im above the sea in iowa and mabie i do how would i check if i have a chip in it?
---Travis--- |
it might have a red wire coming out of it if they decided to use the optional setting. if they didnt you would have to take the ecm down and take the 4 screws out and look in it.
this is over the drivers feet correct, this is where i found the tach wire for my remote start install
---Travis--- |
yea theres 2 modules together a brass looking color one and a flat silver one, ecm and tcm. qty3 10 mm bolts hold them on.. the ecm is the silver one
