Old 09-12-2006, 10:08 AM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
changing the trans ratio
is it true I can buy a legesy trans and put my front diff on it so I dont have to change my rear?
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 09-12-2006, 10:27 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Yeah, but it it is probably easier to change the rear.
Old 09-12-2006, 11:36 AM
IF I REMBEMER RIGHT WHEN i REBUILT THE TRANS THE FRONT DIFF BOLTED ON WITH LIKE 4 OR 5 BOLTS....AND JUST SLID ON THE INPUT SHAFT.
Old 09-12-2006, 12:02 PM
Hocrest's Avatar
More like 8 or so bolts, and you also have to remove the tailpiece to get the pinion shaft that matches the front diff.
Old 09-12-2006, 02:40 PM
no, the pinion is held in by 4 bolts on the front bearing housing and one large nut on the back that secures it to the pinion sun gear. Swapping out gears is a pain in the arse and you are better off leaving the front diff alone and changing the rear and having a 4.11/4.44 4eat...
