HOw much PSi dose everyone go with on their tire for like a day drive. Cuz i have being putting about 33front and back.? WAs thinking of putting it at like 35 or something so i would not have to think about the psi in the tire for sometime
I run about 40 front/36 rear in a stock-sized, all-season touring tire. You should run higher PSI in the fronts; I believe factory spec is 33/29.
dcb |
I know the stock pSI but i'm not running stock tires or rims. The tires size is 225/45/17. So what so i put in then?
Lee, one of the members here, runs 40psi front and 28psi rear.
The 40f/28r tire pressure he is using is almost the same ratio as the 59f/41r weight distribution of the car, so it makes sense that the front and rear tires should have the same loaded radius when at these pressures. For much more information than you ever wanted, check this thread for some interesting perspectives on tire pressure ratios: http://www.subaru-svx.net/forum/show...pressure+ratio .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-20-2010 at 09:51 PM. |
28 seems awfully low to me, even for the rears. dcb |
I get very good even treadwear at that pressure. Ride is a little harsh but I'll take a few bumps in exchange for not blowing a sidewall or bending a rim.
