Old 02-15-2006, 05:38 PM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
tranny problems - just like everyone else
i have the car shift pretty well with it being stock....had the 2-3 flare problem that doesn't seem to have a way to fix. i was told that this was brake band and have read recently that it is not . ~ i'm not concerned about the flaring since a few memebers have the problem as well.
with the shift kit from small car. i noticed that the shifting in general is harder than stock and has the power light flashing once in a while which seems to be normal. trying to do a trouble code, the car says that the car is fine.
now, i have taken the resistor off to ship to budfreak. the power light is always flashing after i start the car. the 16 flashes. but this is not what i am wondering about.
the last few days with and without the resistor on the car. i noticed that while driving on 3 or even D and dropping it to 3 the car would "brake" more particularly towards a speed in which the car would normally be in 4th gear.
i have read about the brake band enough times...have tried to adjust it to fix the flare- when it was suggested to be the culprit...but had pretty much no success with doing it. is this "braking" symptom brake band related or something else? if anybody knows. i will do a trouble code to see what pops up as well.
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 02-15-2006, 06:02 PM
Earthworm's Avatar
Meow!
The "braking" effect is as a result of removing the resistor.
Old 02-15-2006, 06:09 PM
oab_au oab_au is offline
And the the brake band needs adjusting to fix the 2 to 3 flair.
One Arm Bloke.
Tell it like it is!
Old 02-15-2006, 07:00 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
I had the same problem with my old tranny. Without the resistor I had no engine braking in 3rd gear, But I also had no flair. Once I fixed the resistor I had engine braking in 3rd But it would flair. I did the brake band adjustment like 4 times and it didn't help one little bit no matter how I adjusted. It would even flair with only a half turn out on the adjuster Getting 4.44's fixed it
Old 02-18-2006, 08:11 AM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
I have flare too. Been that way for over two years now. I was told that it means the trans. needs rebuilding (estimates vary wildly). I'm not even remotely interested in that, personally; I'll just fix it by switching to a manual. :P
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 02-18-2006, 11:46 AM
i thought as much....
Old 02-19-2006, 07:27 AM
SomethingElse's Avatar
word words wording
when you say flare are you talking about in the middle of a shift it seems to pop out of gear?
Eric
Old 02-19-2006, 07:47 AM
word words wording
nevermind i found it
Eric
Old 02-20-2006, 12:18 PM
Earthworm's Avatar
Meow!
Old 02-20-2006, 03:58 PM
update to this thing
i noticed that this "braking" symptom on "3" is only when the car is at normal driving temps. if i drive the car when i just start it up, then i wouldn't have this "braking"...
i kind of guess it might be the tranny fluid heating up kind of thing.// i dont have a tranny cooler or aux filter in yet.
i'm not crying about the symptoms on the car ~ i know that i have things to get installed/replace/fixed/rebuilt (whichever one it is). but i am slowly rebuilding the car to be as good of a condition as i can get it.
Old 02-20-2006, 04:16 PM
Earthworm's Avatar
Meow!
Yes, this has to do with the engine running in "closed loop" mode (it doesn't rely as much on sensors until the engine is warm) and tranny sensors allowing 4th gear and TC lockup.
Old 02-20-2006, 04:26 PM
thanks for the info ~ david
Old 02-20-2006, 08:09 PM
word words wording
What a great movie...
Stupid tranny goes into 4th when I tell it 3rd
Eric
