mystery plug
On the drivers side of the car there is the grey female end of the 02 sensor and another female end of another plug attached to it. It is a small and oval shaped. Does anyone know what this could be?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
If I'm understanding you correctly, there are multiple plugs wired onto your O2 sensor? Is it a generic O2 sensor with plugs for various cars?
Dan |
well on the passengers side the 02 plug is alone. On the drivers side of the car the same grey o2 plug is taped together in the same harness with another smaller black plug.
Here is a picture PLUG
O2
doesn't look like my O2 sensor plug? 92 LS-L
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Looks like the plug for one of the ABS sensors.
I remember that plug, can't remember what it goes to at the moment.
What is acting up on the car should be a clue. If no one has an answer, i'll check at home tonight while I'm playing with the svx.
I think it leads to the steering rack???
Well i found the other end of the plug. Under the driver valve cover ....and it just started and ran. It was running very rough though. Could this be caused by the lack of manifolds or should i look further....(timing belt )
lol thanks
just out of curiosity, mechanicly what is the lack of manifolds doing to the engine to cause it to run rough.
I'm sure one of our veterans or mechanics on this site can give you a more technical answer, but I'm guessing the engine running rough has to do with the absence of back pressure. I know that removing restrictions from the exhaust path is beneficial (i.e. mandrel bends and free flowing muffler, etc.), but the complete lack exhaust pressure has a negative effect on engine performance. I think that's why all the riceboys who put 3" exhaust and a huge fart can on their 1.8L Hondas actually see a decrease in the already embarrassing amount of torque their engines produce.
Just my $.02. I'll await the more technical replies
- '92 SVX LS-L 5spd. - '98 VW Jetta 2.slow (basic transportation) |
