Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 08-05-2005, 07:57 PM
awdsvxh6's Avatar
awdsvxh6 awdsvxh6 is offline
Send a message via AIM to awdsvxh6
new exhaust
im gonna get my exhaust done this commin week and im not sire how i am gonna do it. i was thinking true dual but there isn't alot of room to get 2 pipes back there. the guy at the muffler shop said get rid of that last cat and put a Y pipe and then make it go into a 3 inch pipe al the way back into 1 muffler and then threw the tips. so i was wondering if that would be the way to go.
Old 08-05-2005, 08:49 PM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
For dual tip exhaust modification...(Assuming you havent used the search option ) check out this thread for lots of info on it and even some of our members have done it..
http://www.subaru-svx.net/forum/show...al+tip+exhaust
Hope this helps if you r really interested in dual tip modification....
-Pavan
Old 08-06-2005, 09:13 PM
awdsvxh6's Avatar
yeah i have seen the tips and i know which ones i am gonna get but i was wondering if anyone has widened the exhaust to 3 inches all the way back to the muffler and what it sounded like or made the car feel like.
Old 08-06-2005, 11:44 PM
KCROGUEDOG
i have 2 and 1/2 and i would not go bigger. u can try but less pressure moving out. 2 would be a good move. i got pics and clips in my locker of my dual system. all walker products (dynomax and thrush)
Old 08-06-2005, 11:48 PM
KCROGUEDOG
i took the all cats of my 97. i get a ce light that is clearable for a day at a time. i got the o2 in my H pipe in no cat. i got a thing called the o2 simulator to stop the ce light deal but ethier i hooked it up wrong or i just dont work. i have not had time to possitively rewire and test. what is the year of your ride. is it obd2?
Old 08-07-2005, 10:17 AM
awdsvxh6's Avatar
mine is obd1 it is a 92 the only cati am getting rid of is the one that links the 2 pipes togethere and leaving the other 2. then from there put a Y pipe and go straight back to 1 small muffler and the out the back with these magnaflow tips im gettin from dayle.
Old 08-07-2005, 05:18 PM
KCROGUEDOG
i wish mine was like that. best thing to do with that is the o2s pick up nothing to do with the catalyst in the exhuast is all about which side is lean or working harder or so on and so on (they even everything out). so cut them off hollow out (or take shell) and weld them on to a straight pipe on each side. so then u pass inspections cause they will look and see that they are there. and u get nothing holding up your flow. i have hook ups where im going to pass inspections but just in case i will resort to welding shells up on each side of mine and clearing my ce light. got to always have a back up plan. and with the single pipe back 3 inches should be great if u got ground clearence which should not be a prob. there is room for dual a good exhuast place will find room and be proud to take the challenge on.
Old 08-07-2005, 05:55 PM
Why not just run straight pipe to a couple cats at the rear?
(Forgive me I know abslutely nothing about exaust set ups)
Old 08-07-2005, 07:23 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I'd suggest you ditch the front two cats and stay with a single 2.5 in/out high flow cat behind a "Y" connecting the two head pipes. Definitely don't go larger than 2.5 inch pipe anywhere in the system....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-07-2005, 07:34 PM
Bill,
Is there any advantage to having the two exhaust pipes connecting at a "Y" and going into a 2.5" SINGLE inlet/outlet high-flow cat?
Chike has the same two exhaust pipes going straight into a 2.5" DOUBLE inlet/single outlet high-flow cat. Is there an advantage to the "Y"?
Old 08-07-2005, 07:59 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by svxcess
Bill,
John,
My 2-into-1 cat has dual 2" inlets and a single 2.5" outlet...
There's no advantage to using a y-pipe followed by a single cat... The 2-into-1 cat is just less complex as both the 'Y' and the cat are integrated into one unit.
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-07-2005, 08:08 PM
SVXRide's Avatar
Yeah, what Chike said
-Bill
p.s. on a purely theoretical level, you'd have to look at how the two flow paths interact in each case to determine the "best" method - flow wise..
Old 08-07-2005, 08:09 PM
KCROGUEDOG
how much is that. that could be my third back up plan to test if they got a 2in 2out for a dual set up with one o2 like a H pipe. really the ce light is getting on the nerves. where to buy? is this what u got on your ride?
Old 08-07-2005, 08:20 PM
Chiketkd's Avatar
Thumbs up
Here's the thread where I talked about my new exhaust:
http://www.subaru-svx.net/forum/showthread.php?t=26752
The 2-into-1 cat ran me $60.77 shipped from www.performancepeddler.com. If you call them (not order on-line) and mention you're from the SVX Network, they've been consistently hooking members up with great discounts.
-Chike
Old 08-08-2005, 02:30 PM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
-Chike
Awsome, that's just the part I was looking for too...Thanks for the tip
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
