Old 08-11-2006, 09:21 AM
DavieGravy DavieGravy is offline
Downshifting into 3rd for no reason
Hello,
For some reason, if I'm cruising at about 60 or so, the car will downshift into 3rd for no reason, and without accelerating. It will then shift back into 4th and do it over again a few seconds later. If I cruise at a faster speed, like 70 or 80, it doesn't happen. Just seems like it's overly eager to downshift, even when I don't need it. Does anyone know what might cause this? The tranny is practically new.
Thanks in advance.
Out for good.
Old 08-11-2006, 10:12 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Originally Posted by DavieGravy
Hello,
Thanks in advance.
I had this happening to mine right after installing the 4.44's. Try cleaning the TPS and setting it properly, It did the trick for me.
Old 08-11-2006, 11:24 AM
Earthworm's Avatar
Meow!
I agree. The TPS tends to wear/get dirty at the spot it's used the most. If the ECU reads a bad signal it usually thinks you've floored it and tells the tranny to downshift.
Old 08-12-2006, 10:37 AM
Thanks. I'll give it a shot and post back.
Out for good.
