Would a 93 or up rear knuckle work on a 92?
Just curious, but I know that the 92's are the ones that have the most problem with the rear bearings. How about changing them to a 93 or up? I know those have the least issues, to my knowledge so far.
Yes, they are interchangeable.
Re: Would a 93 or up rear knuckle work on a 92?
The knuckles are the same, so I'm not sure that changing them is going to do anything unless your knuckles are damaged. You hear more about problems with the 92 models because there are more of those than all the other years combined. Dave |
