Do I need Axle Nut for the Rear Wheel Bearing?
Hi,
Just wanted to ask if its necessary to replace the Axle Nut when I replace my rear wheel bearing. According to the Subaru Technical Bulletins, you have to but I can't seem to find the part # for the rear wheel bearings. Any help would be appreciated. Thanks. -Tony |
Re: Do I need Axle Nut for the Rear Wheel Bearing?
I've used the same axle nut, and put about 30,000 miles on my car since then. I have no problems to this day, I'm sure you can get away with it too. Good luck!
"If it works, tear it apart and find out why!...... ![]() 94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ![]() ------------------------------------ |
